changing steering ratio
Old Oct 9, 2007 | 02:29 PM
dyhppy's Avatar
Default changing steering ratio
never been able to get a usable answer. can a ap2 ratio be installed into an ap2 a la CR? if so how much would it cost?
Old Oct 9, 2007 | 03:17 PM
alejo's Avatar
que?
If you mean an AP1 steering ratio into an AP2; don't quote me but I seem to remember from the CR thread in the R&C forum that it would be a PITA to do.
Old Oct 9, 2007 | 03:43 PM
Saki GT's Avatar
AP2s have two steering ratios, 04-07 and 08+ (same as all AP1s). Honda stated what the exact changes were, but to change over, it would mean a lot of digging.
Keep in mind the steering ratios were dialed into the suspension setting of the cars, so it works as part of a system. You're talking about 2.4 vs 2.6 turns lock to lock, bot a big difference.
Old Oct 9, 2007 | 04:38 PM
dyhppy's Avatar
only the CR in 08 has the tighter ratio. regular s2k has 14.8 ratio.
i just remember the ap1 steer as feeling more telepathic than the ap2
Old Oct 9, 2007 | 04:39 PM
alejo's Avatar
I thought the CR had the same ratio as the AP1 - pretty certain of that.
Old Oct 9, 2007 | 04:42 PM
dyhppy's Avatar
not that i enjoy correcting you, but i have the brochure, but you can check the web site specs. only tighter ratio for CR.
thanks for your help
Old Oct 9, 2007 | 04:48 PM
alejo's Avatar
you should enjoy it
I guess the sources that said here that it was the same as the AP1 were wrong.
Old Oct 9, 2007 | 04:56 PM
Ted H's Avatar
My take on this discussion is that:
dyhppy is correcting you, alejo, on the fact that the AP2 '08s have this tighter ratio--and they don't. But what you keep saying alejo--that the ratio is the same on the CR as was on the AP1--is correct.
Steering Ratio on CR = AP1
Streering Ratio on AP2 (excluding CR) is independent ('04-'08)
Old Oct 9, 2007 | 05:22 PM
MULDER's Avatar
You are correct alejo, the CR uses the Ap1's steering rack.
Old Oct 9, 2007 | 05:24 PM
alejo's Avatar
well, I'm gonna take some joy in that then
