Cheap and light track rims
Old Mar 28, 2001 | 08:56 AM
krazik's Avatar
Administrator
I don't care so much about looks, more interested in find a set of rims for my track days.
I am looking for something that is Cheap & light in a 16" size.
Anyone got any good ideas?
Old Mar 28, 2001 | 09:03 AM
cdelena's Avatar
It's all relative. I decided a second set of stock wheels was the best way to getting replacement tires and track wheels.
Old Mar 28, 2001 | 09:18 AM
Pepe's Avatar
I kind of like the Spoon but are not cheap. Also the offset is small in the front (+35).
I think you best bet will be factory wheels.
Old Mar 28, 2001 | 09:32 AM
Dragonx's Avatar
The last thing you want is a cheap track wheel. I understand you not wanting to put a lot of money into a set that you won't use often, but your hide is worth more and a broken wheel at speed can ruin your day.
Old Mar 28, 2001 | 09:49 AM
pellisS2k's Avatar
I say get a second set of OEM.
Old Mar 28, 2001 | 10:11 AM
Schatten's Avatar
I'm with cdelena and pellisS2k, get a second set of stock rims. I've got mine on the way any day now that I picked up from Power6spds.
What you should also keep in mind, you want consistency in your driving - change the tires, sure, but any wheel diameter and width change will affect your driving VERY DIFFERENTLY at the track than you are normally used to in daily driving.
/my two cents
Old Mar 28, 2001 | 10:13 AM
Unicron's Avatar
krazik,
I have searched and searched. No 16 inch wheel with the correct offset will be cheap.
I found a bunch of expensive 16's like the Racing Hart CP035's (10 pounds).
http://www.racinghart.com/wheel.asp?mkid=20&mdlid=113
I ended up just buying a set of stock 16's and powdercoating them black.
Old Mar 28, 2001 | 10:19 AM
GTRPower's Avatar
Hey-
Do the Kosei K1 wheels fit? Those things are cheap as dirt and light- at least, lighter than what the price would suggest. And, they're relatively strong too.
Old Mar 28, 2001 | 10:21 AM
Unicron's Avatar
At the Jogn Eagle Texas World Speeday event, I saw a guy with these wheels on.
It's not your best bet because he had 16x7 all around and the offsets were all +40mm. He had 205/55/16 A032R's in front and 225/50/16 A032R's in back. His car was not lowered, and if it was...he would be having some serious rubbing problems (I predict).
It's the whie car in the middel, to the right of mine:
They are made by Discount Tire ($120 a piece):
http://www.discounttiredirect.com/mega-bin...7&size.value=16
Old Mar 28, 2001 | 10:22 AM
Unicron's Avatar
GTRPower,
Last time I checked the offsets were not high enough for the 16's.
Please double check for us though...
