Check Engine Light Came on when i hit 90K...
Old Dec 24, 2010 | 10:08 AM
s3kdude's Avatar
Default Check Engine Light Came on when i hit 90K...
My 2002 S2K Check Engine Light Came on when i hit 90K......
Is this Automatic that the Check Engine Light Comes on at 90 K ?
THanks!!!! D
Old Dec 24, 2010 | 10:11 AM
CKit's Avatar
Check engine light or maintenance required light.
For CEL, no.
Old Dec 24, 2010 | 11:18 AM
s3kdude's Avatar
What do you mean ?
Does it come on Automatically at 90 K ?
Old Dec 24, 2010 | 11:37 AM
Elistan's Avatar
He's asking which of the two lights you're seeing.
Check Engine Light comes on ONLY if there is a problem.
Maintenance Required light comes on at regular mileage intervals, which might or might not happen at 90k miles.
Old Dec 24, 2010 | 11:57 AM
rob-2's Avatar
Based only on your miles, you may be getting a CEL as you're due for a valve adjustment and it's way off causing a misfire.
That said, pull the codes. And stop driving it.!
Old Dec 24, 2010 | 12:01 PM
suzuka-blue-s2k's Avatar
If its the CEL, it could be anything. Just pull the code and see what it is. It could be something as simple as a loose gas cap. If its the Maint Req light, that one comes on every so many miles reminding you to do an oil change.
Old Dec 24, 2010 | 01:20 PM
takeshi's Avatar
Originally Posted by s3kdude,Dec 24 2010, 12:18 PM
What do you mean ?
He's trying to verify whether you're referring to the light correctly or not. There's a CEL and a maintenance minder light. It's not uncommon for people to refer to them incorrectly. What exactly does the indicator light look like?
Old Dec 24, 2010 | 04:38 PM
woodburn's Avatar
If the guy has owned the car for 90k dont you think he would know what the maintance light is? In the whole time he owned the car he never changed the oil?
Its might be the secondary air pump code that ap1 get. Thats my guess
Old Dec 24, 2010 | 04:57 PM
CKit's Avatar
Who said he's owned the car for 90k miles? If he was the original owner, I'd think he'd be familiar with the owner's manual. I suspect he's not the original owner.
Old Dec 24, 2010 | 06:33 PM
Elistan's Avatar
He's owned the car for all of 2000 miles.
