Check engine light turned off after putting gas in
Old Oct 31, 2010 | 08:57 PM
Ronss2k's Avatar
Default Check engine light turned off after putting gas in
My cars check engine light came on yesterday I was going to go to my mechanic to get it checked out today. But before I could do that I had to get some gas. After I put in gas the light came off. I was happy, but didn't know why it did this. Anyone know about this?
Old Oct 31, 2010 | 09:22 PM
Armend17's Avatar
Most likely the gas cap wasn't on tight, this will throw a cel.
Old Oct 31, 2010 | 09:29 PM
hrpfg2's Avatar
gas cap.
robmea's Avatar
As said above ! If the gas cap isn't properly tightened the system will detect a small leak in the evap emissions control system. Which will then trigger a check engine light. When you put gas in and tightened up the cap it stopped the leak and therefor fixed your problem !
Old Nov 1, 2010 | 09:06 AM
gtg749m's Avatar
Like everyone else stated. I have an issue with my cap where I can turn it, it'll click 3 times (or 20 for that matter) and its still not tight. What I have to do it hold the cap by the edge of its circumference and turn. A few others have this issue and found it to work as well.
Old Nov 1, 2010 | 12:07 PM
JLUDE's Avatar
This!
Happened to me first time I got gas in the S. the cap will "click" well before it's actually screwed down tight!
Old Nov 1, 2010 | 12:11 PM
zzziippyyy's Avatar
ahh the old Gas cap trick bit ya.....
EsTooTouseng
South Florida
Oct 20, 2010 02:02 PM
mah00si
Sep 18, 2008 10:45 AM
S2000 Owner
Aug 21, 2005 08:39 AM
mrs2k
Jul 15, 2003 07:41 PM
Shinji
Aug 11, 2002 04:09 PM
