check engine sign
Old Oct 18, 2005 | 07:04 PM
BahrainONE1's Avatar
Default check engine sign
ok i have check engine sing on my car and i want to know if it effects on HP car's??
Old Oct 18, 2005 | 07:10 PM
Colin's Avatar
I'd expect a few "sassy replies" to the "Chick Engine Sing" but if your refering to the "Check Engine Light" it could be a lot of things, but if you know the car hasn't been overeved, then the most common thing is a loose gas cap. Did you refuel recently?
Old Oct 18, 2005 | 07:25 PM
Riz2k's Avatar
WHAT?
I'm guessing you ment:
"Ok, I have a check engine sign on in my car and I wanted to know if it affects the horsepower."
I think I'm close, but there are so many random words and usage going on in your statement I could be WAY off.
As for an answer to your question.--Horsepower is not effected by the check engine sign. However, what is causing the check engine sign could affect horsepower. Get it?
Old Oct 18, 2005 | 07:34 PM
oohh oohh soorry guys this is first and last time i asking u ppl
Old Oct 18, 2005 | 08:03 PM
Y2TuCkY's Avatar
you guys scared him back to www.clubsi.com
Old Oct 18, 2005 | 08:30 PM
Colin's Avatar
Don't be so sensative. I was serious, if you have a check engine light on, it could be a lot of things, some are serious, but the loose gas cap is no big deal.
Old Oct 19, 2005 | 06:35 AM
xviper's Avatar
Give the guy a break. He's not from "around here".
A CEL can be triggered by dozens upon dozens of things. Some "codes" may put the car in "limp" mode and then yes, power is affected. If it's a minor codes, like a secondary air injection issue, then this is not likely to affect power.
Old Oct 19, 2005 | 07:41 AM
i have problem with the exhaust sincere and i heard that from my friends if there is a check engine light on the camaro it will effects on horse power like 17 whp lost. . and i want want to know if it's same on s2k!!
Old Oct 19, 2005 | 08:10 AM
xviper's Avatar
We have 2 O2 sensors on our exhaust. The one in the header is the "primary" and if it malfunctions, the engine will not run well. The one in the catalytic converter is the "secondary" and has only a very minor effect on the way the engine runs.
ps. You should have stated this in the very beginning. This would have eliminated many of the strange replies you got. You know the saying, "Crap in, Crap out!"
Old Oct 19, 2005 | 01:01 PM
the catalytic converter is not connected so do think i should connect it or not?
