Check Engine - Why 3 Trips?
Originally posted by OhioRacer
3 trips. Damn thing is still on
-Nick
3 trips, 4 trips, 8 trips WTF??? In the meantime, if there IS something wrong with the engine, I am driving the thing so I can get my 3,4,8, 47 damn trips in to have the system reset itself while the motor is doing damage to itself. Yes, I'm avoiding VTEC until it goes out. Which pisses me off even more. Oh well, I suppose I'm the dumb ass who left the gas cap loose
Pull the fuse. If something else is triggering the light it will come on again. And yes the gas caps for these cars suck. Here's a thread I started https://www.s2ki.com/forums/showthread.php?...?threadid=77847
If i don't take my time putting the cap on it almost immediately starts clicking. If you slowly move through that phase it will stop clicking and start to tighten again. You can then crank down on it until it clicks again. Mine was spilling gas and causing the CEL to come on.
Yeah, I was smelling gas too. Wondered why that tank went so quick
. Is there an aftermarket cap for this car?
I also don't think gas mileage should suffer significantly on account of a loose gas cap; there might be something else going on with your car.
There is nothing wrong with the gas cap on this car. You just have to learn to make it "click" lots whenever you put it back on. That's not to say your gas cap might be the rare defective one.
Lots of people have already told you: PULL THE FUSE!!! If there is truly something else wrong with the car, you'll know right away when the light comes back on. By NOT pulling the fuse and driving around waiting for the light to go off, you are really risking doing some damage should there be something wrong with the car. You would have been far better off to have taken the car to the dealer at the first sign of the CEL since you decided from the get go to NOT pull the fuse. This driving around waiting to see is utter nonsense but then, it's your car.
seems to me that there may actually be a problem with the gas caps. reading thru the previous thread about this i noticed that the problem seemed to occur on '02MY s2ks.
while i do make my cap click more than the recommended 3 times, i have never had this problem with my '01. just an observation.
has this ever happened to anyone with a '00 or '01?
X,
I got in the car (drive #4) and the damn thing was still on. So I took your advice. It worked, although I had a scare. I pulled the "3rd one down" as you suggested. I assumed you meant the 3rd fuse down. Which is what I pulled...7.5 AMPS. Started the car...light still on. SH*T!! Then I decide to take out the "3rd slot" fuse...also 7.5 AMPS (I have no fuse in slot #1). Wallah! Light out. Took it for about a 10 minute drive. VTEC's a few times. Light stays off. Thank God.
X,
