Check Fuel Cap
Old Oct 10, 2008 | 10:17 AM
JackS's Avatar
Default Check Fuel Cap
I accidently left the cap off and got this warning. How do I get this to go off?
I haven't disconnected the battery yet to reset the ECU but it would seem that there would be a way to do this from the dash. I pushed every button to no avail. Any help? TIA
Old Oct 10, 2008 | 10:20 AM
XIEmperorIX's Avatar
how long was the gas cap off?
Old Oct 10, 2008 | 10:38 AM
JackS's Avatar
Twenty four hours.
Old Oct 10, 2008 | 10:39 AM
vincewchan's Avatar
Were you driving without it?
Old Oct 10, 2008 | 10:43 AM
JackS's Avatar
I might have although I never noticed until the next day.
Old Oct 10, 2008 | 11:03 AM
Mrfixit687's Avatar
It will automatically reset it self after the ecu runs the monitor. Just tighten the cap and dont worry about it.
Old Oct 10, 2008 | 11:23 AM
milkstatus's Avatar
yes what mrfixit said will work and should take several days of normal driving , if it is bugging you you can get rid of it instantly by doing this. Tighten fuel cap till it clicks . Start engine, turn key to off. Then repeat the starting process 2 more times, and it should reset.
Old Oct 10, 2008 | 11:38 AM
JackS's Avatar
Thanks guys. I'll try the restart method this afternoon.
Old Oct 10, 2008 | 11:55 AM
JackS's Avatar
Just tried the start/off sequence and it didn't work. No problem though, I'll drive it a couple of days and if I still have the warning, I'll disconnect and reconnect the battery. Thanks again.
Old Oct 10, 2008 | 11:56 AM
SheDrivesIt's Avatar
It has to go through several driving cycles including full warm-up of the car. Just drive it normally and it should go away after a few cycles. The method described above will not work.
