Chip Modification
Old Nov 11, 2003 | 08:19 AM
JPit's Avatar
Default Chip Modification
Is anyone familiar with Jet Performance chip upgrades? They have one available for the S2000 and you have to send in your ecu. Costs $300.
Old Nov 11, 2003 | 08:48 AM
seung's Avatar
scam.
Old Nov 11, 2003 | 08:53 AM
JPit's Avatar
Maybe it is a scam but Honda was able to get about 10 hp more upgrading the 02 ecu and apparently have done some more tuning for 04 - leaning out the A/F a little.
Old Nov 11, 2003 | 12:01 PM
ultimate lurker's Avatar
Don't buy Jet. They can't alter the ECU. At least not for $300. The programming is encoded in the microprocessor memory during the semiconductor fab process. It can't be changed unless you change the microprocessor, which costs more than $300/chip in small quantities.
UL
Old Nov 11, 2003 | 12:25 PM
HI SPEEDR's Avatar
My feeling is that Honda has engineered the S to get as much HP as possible. They probably already have the best chip for the car. I don't think I would screw with it. It also might screw up your warranty if it's still active.
Old Nov 11, 2003 | 12:26 PM
JPit's Avatar
UL, thanks for the info - it's nice getting right to the top so quickly. Now that I've got your attention what kind of problems will you run into using a JDM ecu? Thanks.
Old Nov 11, 2003 | 12:30 PM
No immobilizer for one. I would suggest that if you don't want to spring for a Mugen ECU (or even more $$$ for an AEM EMS), pick up a VAFC and be done with it. THe emanage is another option, but will require more tuning.
UL
Old Nov 11, 2003 | 12:38 PM
Road Rage's Avatar
[QUOTE]Originally posted by HI SPEEDR
Old Nov 11, 2003 | 01:07 PM
JPit's Avatar
UL,
One other quick question. I assume the VAFC doesn't alter ignition timing so would it be better to have an my02 ecu rather than my00. Did we ever find out why the 02s produce a little more power?
Old Nov 11, 2003 | 01:55 PM
MacGyver's Avatar
UL
Do most ECUs use a fairly standard chipset with masked ROMs or are they totally custom? If it's a standard chipset, swapping it out would be quite easy once the program is done. We're not talking Pentiums here...something in the area of a 16-20 Mhz, COTS processor is more than adequate, like a 68HC16, etc.
