Cigarette lighter / 12 volt accesory outlet?
I try to avoid the dealer at all costs, only for absolutely last resort will I bring it to the dealer, and especially not for this.
Thanks for the how to rworne, I will do it this weekend.
You might also want to try loctite or something else to prevent it from happening again. When the dealer put in my airbag switch, he saw the loose port and fixed it at no charge since he was tearing up all the trim in the back anyway.
Thanks, I have taken that area apart before when I did my stereo system install, but n ever the glove box. I might just put a temp fix which will be to use silicone to hold it in place, I really dont feel like tearing that area apart again. Its a pain.
i had the same problem.. it has always been loose since i got the car a year ago.. i don't use the outlet much.. but i just got an ipod and was trying the fm transmitter.. went to remove it and the whole thing popped out... i'll have to try this fix this weekend.
let you know how it goes
For this reason I installed 4 12v outlets under my seat. So I can charge things and not have to worry about taking up arm room, or breaking that outlet...perhaps stick that back in and install another one somewhere else?
-Jason
-Jason
I finally fixed mine.
Basically you have to go in thru the driver's side, I could not reach it from the pax side. Move the driver seat forward as far as you can.
You will see the two little brackets for hanging things I guess, remove both, they have a cover u have to remove to gain access to the screws. Once removed, remove that panel, basically just pull it out, it snaps in.
Then there is one screw right by the center console that you have to unscrew, this will allow you to lift up the bottom corner of the console to put your hand in. Also I took out the screw out in the middle of the center console in the compartment.
You have to have small hands, but just pull the console up, slide your hand in and then rescrew the sleeve back on the lighter. Then put it back together. Its a tight fit, but it can be done.
Good goin'
-Hockey
