Clearing Headlights
Old Jul 28, 2002 | 02:09 PM
Utah S2K's Avatar
The "gospel" as written by Arnell........
https://www.s2ki.com/forums/showthread.php?...?threadid=50775
This is the definitive thread on the subject here.
Utah
Old Jul 28, 2002 | 02:10 PM
SECRET AP1's Avatar
Originally posted by Utah S2K
Bake it with the ballasts in.....no problem. Use the "gospel thread" on the subject here; but increase your temperature about 10-20 degrees. Now comes the hard part. The recipe calls for putting the housings on a damp towel (precludes melting of the housing). This is the step a lot of folks have moisture induced in. They look dry but their not! Let the silicone dry 24 hours and then bake at 100 degrees for about an hour....no moisture. An alternative I have used on 3 impatient clearings is to run the headlights for about an hour with the turn signal bulbs out (sockets hanging loose). Any moisture is driven out the turn signal hole.
Good luck......and it will look awesome!
Utah
leave the towel out. be weary of the way you place your headlights on the rack and you'll be fine. the towel's just going to cause a mess and lengthen the time it takes to do a simple job. i did mine without any towels, and it worked out great.
Old Jul 28, 2002 | 03:11 PM
darkknight1999's Avatar
Don't use the towel, just use pot holders. They will protect the housings and will not burn and the best part no water in the headlights.
Just follow the regular directions but use pot holders instead.
Old Jul 28, 2002 | 08:40 PM
S2Thizzle's Avatar
Thanks for all the input fellas. I just baked everything (including the ballasts) and it worked fine. I used a ton of silicone to seal the housings. So far, I've had no problems with moisture entering headlights. Removing the front end and headlights was very easy. Getting the housings open.....another story. Well, after all that hassle, I'd have to say it was definitely worth it. Here's some pictures. I'm waiting for my clear side markers (on order from Rick's).
Old Jul 29, 2002 | 09:10 AM
Nice job
slvrAP1ftw
Oct 21, 2008 04:02 PM
J_STATUS
Apr 14, 2008 07:21 AM
s2kev
May 3, 2006 01:07 AM
Ooalloems2koO
Jan 14, 2005 02:08 PM
