clock on console cover mistake
just had the rick console cover (thanks rick- looks great!) installed (thanks prolene- you made it look really easy!), with my clock mounted on it between the radio and stick shift. the clock is held on with velcro (self-adhesive holds the velcro to the clock on one side and the console on the other). this morning i pulled the clock off to change the time and the console cover pulled out! so i want to share two things:
1. when removing your clock from the console cover, be sure to hold the console cover with one hand while removing the clock with the other.
2. if you make the mistake that i made, just pull out your credit card and use it to push the cover back under the stereo cover. it takes a couple of minutes, but you dont need to pull off the stereo cover to fix this...
