clutch play
Old May 18, 2025 | 10:15 PM
jjjjohnignacio's Avatar
Default clutch play
So I just recently changed my leaking clutch master cylinder and I bled the clutch fluid… however I feel like there’s still a bit of play when I press on the clutch. Is it possible there’s still air in the system? Or is there anything else I missed? Just an fyi, I recently got my clutch changed w oem pressure plate, oem disc, act streetlite flywheel, and I changed to the ap1 slave cylinder.
Old May 19, 2025 | 07:10 AM
Car Analogy's Avatar
There could still be air, but might just be pedal freeplay adjustment needed.
If there is still air, best method to remove is gravity bleed:
Old May 20, 2025 | 09:28 AM
CTRCAL's Avatar
Which method did you use? Gravity bleed method does not work well at all after replacing hydraulic components. Might work if youre just getting old fluid out
Use the 2 person method and your pedal feel will return to normal.
Old May 20, 2025 | 09:38 AM
Yeah I just gravity bled, I basically used most of the bottle. It seems to be shifting fine just a little bit of play even with the push rod adjustment. I’ll def get it up again to do the 2 man bleed just to be sure.
drewc
Aug 8, 2015 01:07 PM
emaos
Jun 26, 2015 10:19 AM
SamySnead
Jun 3, 2015 03:44 PM
iLuveketchup
32
Feb 20, 2015 09:16 PM
prj3ctm4yh3m
Jun 26, 2011 12:59 PM
