Clutch question, is this normal?
Old May 8, 2007 | 08:09 AM
  #21
StuE.'s Avatar
I feel a click/pop in the pedal AND hear it. it doesn't happen every time though. it's really weird. I hope it's just an adjustment. It has never done this until this past Sunday.
Stu E.
Old Jul 26, 2007 | 11:53 AM
  #22
udr's Avatar
udr
bump up this thread for answers. I just noticed a clicking noise when I depress the clutch. Anyone know?
Old Jul 26, 2007 | 06:44 PM
  #23
RGBenderKC's Avatar
Hey guys, I had this EXACT same problem on my 2003 Civic Si. The push rod between the clutch pedal and the clutch master cylinder was binding. I did some experimenting. If you loosen the nut, you can screw/unscrew the rod to adjust it. It only took a 1/2 or 3/4 of a turn to get rid of the click. It only takes very tiny adjustments to make a difference!
Before doing that...before I even knew what the problem was, I took it to the dealer to get it fixed under warranty. All they did was lube the clutch pedal linkage then kick me out the door. I did not realize there was a TSB at the time...
Old Jul 26, 2007 | 10:43 PM
  #24
RACER's Avatar
[QUOTE=JackS,May 7 2007, 04:06 PM]If your clutch isn't slipping and you don't have problems changing gears. you probably don't need an adjustment.
Old Jul 26, 2007 | 10:45 PM
  #25
RACER's Avatar
Mine dun't click.
Old Jul 26, 2007 | 10:46 PM
  #26
RACER's Avatar
*crosses fingers*
Old Aug 13, 2010 | 03:28 PM
  #27
6million$man's Avatar
BUMP to this thread....
Still no solution or explanation on clutch clicking when depressed....anyone know?
TIA!
Gh0ztt
Feb 18, 2008 06:43 PM
sector47
Jun 19, 2007 12:27 PM
shastsmae
Mar 9, 2005 02:51 PM
