clutch released?
Old Jul 21, 2001 | 12:35 AM
s2k-white's Avatar
Default clutch released?
please help:
Does anybody have a clunky noise when releasing clutch on reverse and if anybody knows please explain........
Old Jul 21, 2001 | 08:59 AM
lvs2k's Avatar
The noise you are hearing is most likely not clutch-related at all. What your probably hearing is the rear brake pads popping loose from the rotors. Any moisture or even humidity can cause enough oxidation (rust) to cause the pads to stick to the rotors. When you release the e-brake the pads do not release until you begin to back up, and then they "pop" loose; totally normal, I think. This is especially noticeable after washing or any other wet condition.
Old Jul 21, 2001 | 09:21 AM
s2k-white's Avatar
it is more like when you engage and disengage the clutch it feels, while on reverse like it takes a second to engage and you hear the "clunk" sort of noise like it hits the drivetrin or something......
Old Jul 21, 2001 | 10:24 AM
john's Avatar
Mine does it too. I thought it was slack in the linkage being taken up. Ideas?
Old Jul 21, 2001 | 10:26 AM
Utah S2K's Avatar
...listen to LVS2K he has the most posts....and the correct answer.
Old Jul 21, 2001 | 10:29 AM
Utah S2K's Avatar
Feels like that because for an instant you are fighting the brake pad friction, then the pads release. Was the car in the rain or recently washed....this is when it is most often noted?
Utah
Old Jul 21, 2001 | 12:25 PM
jerrypeterson's Avatar
That is probably your differential engaging in reverse. You are likely hearing the plates clamp together and spin in the seldom used reverse direction. This is usually loudest when you have a new car. This is normal.
tomair
Nov 15, 2022 09:45 AM
UtS2K
Jun 4, 2014 01:57 PM
chubbys2k
May 29, 2014 11:57 AM
AZDavid
Aug 22, 2006 02:10 PM
localizer11
Feb 22, 2004 06:44 AM
