Cold start Knocking metalic sound , Help!!
Old Oct 18, 2025 | 04:31 AM
Robys2k23's Avatar
Default Cold start Knocking metalic sound , Help!!
Hello guys, I have a 2000 Honda S2000 AP1, and when I start the car cold and the weather is chilly, the engine idle fluctuates a few times and at the same time it makes a strange metallic noise — kind of like engine knocking or something similar. It does this until I press the accelerator slightly, after which it goes back to normal and everything runs fine.
I should mention that the TCT is new, as well as the timing chain and guides, new spark plugs, new ignition coils, new oil and oil filter, new solenoid, new knock sensor, and AP2 retainers.
I’ve been having these symptoms for about a year now, and I’ve noticed that it doesn’t happen during the summer when it’s warm — only when the temperatures are low.
If anyone knows what’s going on or has experienced something similar, I’d really appreciate it if you could let me know! I got a Video with the moment of the problem to !
File Type: mov
Old Oct 18, 2025 | 08:38 AM
windhund116's Avatar
The audio sounds like some loose sheet metal or bracket.
Old Oct 18, 2025 | 10:24 AM
Robys2k23's Avatar
Yes , sounds like that but why its happening just when its cold ?
Old Oct 18, 2025 | 10:39 AM
noodels's Avatar
Would guess fuel starvation,vac leak maybe,is it spitting back as sounds like it !
Old Oct 18, 2025 | 11:04 AM
Robys2k23's Avatar
I hope to be something like that , but in my ears sounds like metal in the engine , tomorrow i will ask a friend to start the car and i will take a video from the engine bay to see from where its coming , hope to dont have some internal engine damage but its strange because the car runs fine , i take the oil pan out to see any metal inside but there is none shavings , same for the solenoid screen , strange because this problem its been here for a year or more
Old Oct 18, 2025 | 11:42 AM
If it sounds like it's coming from the engine, I'd remove the valve cover and do a thorough inspection.
Good luck!
Old Oct 18, 2025 | 12:28 PM
Robys2k23's Avatar
So i had this issue for over 1 year now and in June i taked off the valve cover and i changed the retainers to ap2 ones , new tct in the same time new chain , guides , oil pump chain and guides too , new solenoid also , new knock sensor , not a single problem on the superior part of the engine to be found , the old parts have been in great condițion too but i changed them just to be sure everything its ok an safe , but this problem was present Before and after this job too , that’s why i dont understand , also i searched for metal shavings in the solenoid screen and in the oil pan and filter but i dont see any amount of metalic material
Old Oct 19, 2025 | 05:14 AM
Chuck S's Avatar
What new TCT did you install? Wholesale changing of the parts you mention is rarely needed.
Are you really in Romania as your "about me" shows? (Just curious.)
-- Chuck
gamer77
May 12, 2022 12:32 AM
sanchez
Aug 21, 2013 10:47 PM
deegaw11
Dec 5, 2012 06:40 PM
adz9
Feb 22, 2008 02:28 PM
TooFly
Jan 27, 2008 06:50 AM
