Common Problems MY04-MY06 ?
I searched and found only threads for the older years. I am thinking about getting a S2K and would like to know about common issues that the mid year (2004-2006) models have that are either TSB's or recalls or even issues the factory doesn't acknowledge.
Originally Posted by Saki GT,Jun 11 2008, 12:06 PM
We have 04 TSBs in the Library here, but in general, the 04-05 S is solid - no issues - they don't even burn oil.
I am being totally serious as I have just started looking into getting one and that would put a lot of points on the yes side.
I am trying to decide between a S2000 and another car, but that's a different thread I will start.
Originally Posted by JH225,Jun 11 2008, 12:47 PM
Get out! The 04-06 doesn't have any issues to speak of? No brake rotors, no transmission/shifter/syncro, no window motors, no electrical, nada?
The only thing I'd look would be the differential, but that's hard to tell from just one test drive.
Since it's 04+, over-rev shouldn't be THAT much of an issue, so..
I guess the differential is the main one you should be worried about.
Good luck finding a nice one!
Dan
I have an 04 @ 58k miles. I have top wear (1inch tear) but that was prob because of prior owner neglect.
-ALWAYS look at the top inside and out for wear. Highly recommend inspecting/replacing the elastic straps.
-My cat just went out on me (combs rattle around) but if you're completely stock that is a guarantee warranty replacement item (under 80k miles).
Other than those two problems, i haven't had any problems. I burn not a single drop of oil between my 5k oil changes. Knock on wood.
