Condensation in Left Headlight
Old Aug 2, 2001 | 06:56 AM
DoubleB's Avatar
Default Condensation in Left Headlight
Any one else have this problem? The right is crystal clear. The left headlight has moisture droplets inside entire lens. Does it need replaced? and if so, right away?
Thanks for any help.
Old Aug 2, 2001 | 07:19 AM
ace039's Avatar
did you clear out your headlights before!? If so, you must of not completely closed the gap between the headlight and the rubber that your suppost to melt. Thats probaly it, just go back and find the spot where theirs a little hole and fix it up. If you haven't cleared out your lights, then i dunno. Take it back to honda.
Old Aug 2, 2001 | 07:54 AM
DoubleB's Avatar
I haven't done anything to the car, yet. It only has 2k on it, so I assume it should go the dealer.
Old Aug 2, 2001 | 07:55 AM
DoubleB's Avatar
and what does clearing out lights refer to? Cleaning?
Old Aug 2, 2001 | 12:57 PM
Jaded41's Avatar
No, clearling out the headlights refers to openning them up and removing the orange corner reflector. Japanese and European models have a clear corner refector and it looks much nicer. It's way too expensive to buy those housings, so a lot of us Americans just open up the headlights and take out the orange one to make it look similar to the clear one. It's not perfect, but it's a cheap fix to what would otherwise be an expensive problem.
Check out this link...
Clear Headlight Conversion
caraficionado
Sep 23, 2013 12:08 PM
viewmtrp
Apr 27, 2012 04:54 PM
kylemonster85
Dec 28, 2009 02:35 PM
kki3o
Mar 11, 2002 07:11 PM
cjb80
May 5, 2001 11:03 PM
