Conservative shifting?
Then again, I don't care about MPG or whatever, I just do it so I don't look like the asshole revving the shit out of my car from stop light to stop light.
To those who feel uncomfortable holding the car in a lower gear with the tach past 4K, how do you feel about going 80mph in 6th (do you want a couple more gears)? This engine seems 'happiest' when it's revving and it can do it all day long without suffering. It also makes it easier to modulate the speed of the car (with a single pedal) - finer control and greater range of acceleration/deceleration rates.
^ I generally feel uncomfortable holding the car in first or second gear for an extended period at 5,000+ RPM (4k is usually my shift point, so I don't feel too bad at holding it right at 4k), but I certainly do not think the car needs to be geared higher without forced induction. I generally do not drive 80 mph for an extended period of time, but I would have no problem going 80 mph in sixth gear on the freeway for an hour straight if I didn't have to worry about a speeding ticket or other cars slowing me down.
As to answer the original question in this thread, I usually shift between 3-5k when daily driving, but I do like hitting Vtec from time to time
I'll admit though, in first and second gear, I have done my share of granny shifting around 2,500 rpm, and when conservative on the throttle, I have actually not noticed it bogging down as bad as I would have thought.
I agree about the hill example, when you do care more about the torque curve, shift down, but you basically need no torque at 35-40MPH. In the linked thread they say at higher PRM, the pumping losses/extra friction/extra engine braking > increased torque/effiency. I don't have a ScanGauge but people have probably made exact curves on hypermiler forums. Less scientifically if you look at people who need to save gas, i.e. taxi drivers who drive manual, they all shift their 2-liter engines at like 2-2.5K.
My friend who's taking an automobile engineering class actually had a chart where it listed RPM + power output (?) and fuel efficiency. It's for a generic engine but I thought it was pretty cool example of the tradeoff.
Yes, I do wish there were one, or sometimes two additional gears. The car feels most comfortable cruising at 4k rpm. I wish I could be at that rpm even at higher speeds. I wouldn't want to raise the final drive, just wish the were another gear on top to use.
It seems Honda geared 6th to make sure you could cruise at 55 mph without going below the ~3k rpm that they seem to want to keep you above with their suggested shift points. But that means you will be at much higher rpm with more velocity.
While we're talking about lower RPMs, does anyone else notice an excessive amount of trans noise in the lower RPM range in 1st and 2nd? For instance, at parking lot speeds? I'm relatively fresh to this car, and still trying to acquaint myself to the noises it's supposed to be making and the ones it's not.
