Convert single exhaust to single, keep dual tips
Old Jan 23, 2006 | 06:30 PM
24s2k7's Avatar
Default Convert single exhaust to single, keep dual tips
Just wondering. I was looking at my Invidia today and something popped into my head. I really like the performance of Single exhaust but hate how it looks on AP2's. Couldn't you just customize the Invidia, or any dual into a single, close off the opening to the left side muffler, but keep it welded together for the dual look?
Old Jan 23, 2006 | 06:48 PM
XclusiveAutosports's Avatar
You could always do some type of custom inline electric exhaust cutout so you could weld in a valve in the driver's side pipine and close it from in the cabin when you want the performance of a single. Just an idea
Shortly i'll be running an exhaust cutout that will bypass my restrictive HKS dual all together and it will open up after my downpipe/testpipe, but with a turbo it is much quieter then running open header on a NA car . In your case I would just run the exhaust valve or cutout inline with the driver's side instead of using a Y-pipe to bypass the exhaust. Good luck with it.
Old Jan 23, 2006 | 06:50 PM
24s2k7's Avatar
The difference in gains between single and dual has to be where the exhaust splits into two. So fix that problem, and you should gain some power, right?
Old Jan 24, 2006 | 03:53 AM
That is what I was thinking. I would put the flange right where it splits (or weld it in right after it splits) to make it operate like a single.
Old Jan 24, 2006 | 04:19 AM
Gink5's Avatar
i have a spugen single and i was trying to think of a way to pass it through two muffler at the switch of a button. This way it can be quite when i need/ want it to be. Do they make valves that you can control for this purpose? I know porsche has them.
Old Jan 24, 2006 | 06:16 AM
F20Chris's Avatar
Here are a few cutouts, they would have to be modified, but could work. Hope it helps.
http://www.jcwhitney.com/autoparts/Product...0012746/c-10114
Old Jan 24, 2006 | 06:28 AM
24s2k7's Avatar
How expensive would this be to get done? Seems pretty simple!
Old Jan 24, 2006 | 06:59 AM
Wisconsin S2k's Avatar
moving to S2000talk
Old Jan 24, 2006 | 07:14 AM
Gink5's Avatar
Thanks man.
Old Jan 24, 2006 | 08:01 AM
I bought my exhaust cutout from here, he had great customer service too
http://www.badlanzhpe.com/index.html
I'm not sure if it would work inline with your exhaust though.
