Countersunk shift knobs
Old Jan 2, 2007 | 05:20 PM
  #41
lilazngrl4o8's Avatar
titanium voodoo knob for me. worth every penny.
Old Jan 2, 2007 | 05:25 PM
  #42
HARDtoTOP's Avatar
Originally Posted by S2kracka,Jan 2 2007, 09:16 PM
Wish I could tell you, but I just have the tools I use for it in a bag! Search around for it though, I have a thread on it somewhere that states the size drill bit and tap I use.
I have a spare knob here, I'll make one for ya
Did you use a drill press or did you hold the knob in a vice and do it with a hand drill?
Old Jan 2, 2007 | 07:27 PM
  #43
infinity_racer's Avatar
i wrapped the knob in a big welding glove and put it on a vise and drilled slowly as evenly as i could...i just recently got a drill press so i'll be doing it over and making it more even
Old Jan 2, 2007 | 07:29 PM
  #44
HARDtoTOP's Avatar
After some searching, I have discovered that the thread size is a 10 x 1.25mm
I might try to mod my 02' leather wrapped knob.
Old Jan 2, 2007 | 07:53 PM
  #45
S2kracka's Avatar
Wrapped the knob in a towel, put it in a vice, and drilled by hand.
Old Jan 2, 2007 | 07:55 PM
  #46
S2kracka's Avatar
It will probably fall apart on your since the knob is not solid. Best case scenario you'll just have to glue it all back together when you're done. It will be much harder though, especially since the threaded insert is steel instead of aluminum like the 00-01 knob.
Old Jan 2, 2007 | 08:00 PM
  #47
HARDtoTOP's Avatar
Great. Thanks for letting me know though before I ruined a good knob.
I am now thinking I may commision a co-worker who owns a machine shop to make one for me. this way I can get the shape and weight I want. Probably alot cheaper too.
Old Jan 2, 2007 | 08:30 PM
  #48
S2000Patrick's Avatar
I'm like the majority of the people here. Voodoo is the only knob I like the feel of.
I've used the OEM AP1, OEM AP2, a heavier knob that was borrowed from another member, I don't recall which one it was, and have had 2 different Voodoo knobs.
Old Jan 3, 2007 | 04:08 AM
  #49
HARDtoTOP's Avatar
I'm not big into the feel of balls in my hand That's the ony reason I don't think the voodoo will work for me. Seriously, I am not a fan of the shape. The more oblong examples seem to be better for me.
Old Jan 3, 2007 | 06:31 AM
  #50
Triple-H's Avatar
As far as I'm concerned the Muz knob really is the best. I had a Voodoo and the thing was too small I hated it. Not only is the Muz slightly bigger but if engraved the set screw allows you to place the shift pattern perfectly.
