CR suspension vs Bilstein PSS9
Originally Posted by Vik2000,Nov 28 2008, 02:01 PM
I really don't think it's worth spending that much on CR suspension...
Originally Posted by SiDriver,Nov 27 2008, 06:39 PM
CR --> 375 front/264 rear
PSS9 --> 345 front/285 rear
Originally Posted by Terror,Nov 28 2008, 05:21 AM
I don't think he asked
I've never ridden in a CR or CR equipped car, but I have ridden in a PSS9 equipped car. I must say, it was both comfortable and "confidence inspiring" at the same time.
I am also running the PSS9 setup on my '08. Love it. Having driven a CR I would say the PSS9 damping is much softer at the "9" setting. At full stiff "1" - it will be much stiffer than the stock CR suspension... you will feel every crack in the road and probably loose some fillings.
Only issue I find is that the height is hard to adjust "precisely". Although, I would assume this is a problem with all coil overs.
Have you changed your sway bars from stock? And if not, do the PSS9s reduce body roll compared to when you had on stock coilovers?
