Crashed Spakry last night!
Old Feb 23, 2001 | 05:01 PM
Sparky's Avatar
Actually, by some miracle, the damage was minimal. There was a rock slide on my road last night and at about 1:30am, I was coming home and just over the crest of a hill was a pile of rocks spread across the entire road, and there is no shoulder.
I basically had 20 feet to react and stop. I failed. Actually, I could have reacted much better. I wasted a good 10 feet just trying to figure out how to avoid the situation, and by the time I made a decision, it was way too late to execute it.
So, I went straight through entire pile of rocks, and thought I would miss the biggest one - a one foot cube. Apparently my right front tire hit that one, and it ripped the sidewall of the tire completely open. The tire has a semicircle gash with a radius of approximately 3 inches. By some miracle, there is no visible damage to any other part of the car, which is very surprising, given the spread and size of the rocks I crossed.
So, this tire is basically irreparable, and I need to order a new one. Problem is that all four tires have approximately 1.5mm of wear before the wear bars. If I put on a new tire, I will have completely uneven tires.
Now, on the other hand, I only have ~6,000 miles on these tires (11,500 miles total, and this is my second full set) and all four are worn pretty evenly. I would like to postpone installing new tires as long as possible, since I am spending more money on tires than I am on gas!
Should I install a whole new set of tires, or should I just replace the one?
Does anyone have a well worn front tire they are replacing anyway that I could use to postpone the inevitable?
Old Feb 24, 2001 | 03:53 AM
drmark's Avatar
It's on the front so just drive around with the mini spare for a while.
Just kidding, sorry about your tire but glad your Stook is ok.
Mark
01 TheBlackBeast #0090
Old Feb 24, 2001 | 07:57 AM
Sideways's Avatar
Sparky, sorry to hear about your problem. I would just change out the front tires and check the wheel ( and the car) out completely for unseen damage. These cars can have hidden damage than won't show up immediately. Good luck.
Old Feb 24, 2001 | 01:57 PM
Utah S2K's Avatar
Good advice Sideways. Have the wheel dye pentrant inspected at a speed shop before you put on new rubber. Replace both for even wear....
Old Feb 25, 2001 | 12:02 AM
Sparky's Avatar
Diddn't think of testing the wheel. I diddn't even know that could be tested. Thanks!
I just ordered a set of all 4 tires from TireRack, since the rears are pretty close to the wear bars too. I am off to Europe tomorrow, so the tires should be in by the time I get back, and so should all of Ricks accessories.
I'll have the dealer check out the car for other damage too. The rocks covered the entire road, and I just can't believe I could be this lucky that it only cost me a tire.
project2k4
Sep 13, 2012 08:22 AM
THES2KWAY
Apr 30, 2005 12:47 PM
dizzy
Sep 10, 2001 11:10 PM
1Y2KS2K
Jun 20, 2001 08:47 AM
nolas2k
May 13, 2001 11:02 AM
