Cruising gear
4,000 RPM and whatever gear that is to be at that speed.
I pretty much keep my motor above 3,500RPM at all times, always have for 30+ years, my other car has a 8,500RPM redline and still runs just fine after 32 years of driving at 4,000RPM so I figure the S can do the same.
Oh of course ONLY after the motor is hot, until then I shift at very low RPMs, don't lug but close.
I always thought the less LOAD you put on your engine, the less fuel needed to keep it "cruising" because at WOT aren't you making the car try to burn more gas "faster" in which gives "more" power at the engine? More throttle = More air = More combustion?
Well that's what a reputable someone has told me once. He might be on drugs, or he might be onto something.
Originally Posted by NFRs2000NYC,Jul 27 2010, 12:44 AM
Your gas mileage is based on how much gas you are squirting, meaning, how hard you are hitting the pedal on the right. For you to pass a car (generate x amount of inertia) in 3rd might only require 1/4 throttle, but passing the SAME car in 6th might require full throttle, thus, the same result is achieved using MORE fuel.
You've neglected to account for the fact that in the second scenario, being in 6th gear, the engine is turning at a lower speed, and therefore you have fuel injection events with less frequency. So you're putting in more fuel per revolution of the engine, but you're doing that less often. And my understanding is that the overall effect is to use less fuel.
I usually shift around 4000rpms and get to the top gear as soon as possible. I try not to let the rpms dip below 2500 as it really bogs the engine down. When necessary, I downshift and then work my way back up to 6th. 35mph might be too slow for me to be in 6th without bogging, so probably 5th gear. 40mph and up, I usually cruise in 6th gear.
On a side note, I have read alot of drivers state that braking at a stop light in neutral, or just plain slowing down while having the car in neutral is bad. Can anyone explain why? I'm trying to figure out if its an actual technological/mechanical reason or a safe driving reason? I have been doing that in every manual I have ever had with no issues, but if it's really not recommended, I want to understand why and then change my driving habit.
Thanks!
Thanks!
Thanks!
Thanks!
There is another reason to decelerate in gear, down to low rpms and speed. The speed sensor is expecting you to be in gear when the car is rolling so when the rpms go to idle while you're still traveling at 25-50 MPH the ECU doesn't know what is going on so it pumps in extra fuel to be on the safe side and runs a richer curve to idle till the speed comes down close to zero.
Originally Posted by PWRMKR,Jul 26 2010, 04:13 AM
this is what i base my cruising speed on.
is that from an ap2 manual? in the version i have for the ap1, shift into 4th is at 63kph.
which is kinda what i was getting at with this poll.
if the shift is at 63kph but the speed limit is 60kph, your kinda left sitting on the fence about what gear you should be in.
as for fuel economy, once you start moding your s that all goes out the window. but i was always told lower rpm's creates more compression, hence leading to more fuel consumption. but what do i know, i'm just a tiler.
You actually will burn LESS fuel with larger throttle opening at lower rpm in a taller gear than you will at the same cruise speed with a smaller throttle opening at HIGHER rpm. This is because of reduced internal frictional losses per mile at lower rpm and reduced pumping losses with the wider throttle opening.
The pedal on the right does NOT directly control the amount of fuel into the engine.
Originally Posted by Ape-x,Jul 27 2010, 05:41 PM
I was waiting for someone to pull out their manual and scan that page.
If you're cruising at 35mph in 3rd gear, all you're doing is wasting fuel (and eliminating need to downshift when/if you do need to accelerate or climb a hill).
