Damn gas cap!!!
might it be that you aren't getting it all the way on? a very common problem (that mine has as well) is that the clutch mechanisms lets out too early, and it starts clicking before it really is on there. try holding on the outside, or pushing down on the top of it while screwing it on. chances are that you'll get several more turns on it.
good luck,
epi
good luck,
epi
Yes, mine has similar behavior. Like epnfrn said, if you hold the outside while you turn it (and turn it slowly), you will find that it goes on several turns past where it normally starts clicking.
My '02 has the same problem. You can fix it by turning the gas cap using the outside circumference of the cap, instead of just the tab in the middle.
Grab the round circumference of the cap and tighten it for a few clicks. Then tighten it a few more clicks using the tab in the middle. After a few driving trips, your CEL should go off and stay off.
too weird
