Daytime Running Lights
Old Jan 31, 2008 | 05:02 AM
S2KJOY's Avatar
Default Daytime Running Lights
I'm in the process of imporing a 2004 into Canada. What is the best way to deal with the Daytime Running Lights issue? I have everything ready for the inspection except for DRL. Once I have the issue solved, I can go to crappy tire, get the inspection done and then plate the car.
I have read a few posts here but don't have the time to search everywhere so any advice would be much appreciated.
Old Jan 31, 2008 | 05:43 AM
ace123's Avatar
you can wire it yourself i suppose--just force the halogens to come on when the ignition is positive.
one possibility: you'd have to locate the headlight on/off switch (the wire) and then take a wire that turns on power when the ignition is on. one is the blue wire from your radio. then tie the ignition wire together with your headlight on/off switch. not sure if the blue wire will have enough power on its own so an amp may be needed, and im also not sure the on/off is positive-on; this is just a guess based on non-HID cars. modifry or others may have a better idea.
Old Jan 31, 2008 | 06:44 AM
AP_ONE's Avatar
There are a lot of shop that will let you pass w/o day time runnign lights. I know Im supposed to have them by law here in Ontario and I dont, no issues ever
Old Jan 31, 2008 | 07:58 AM
INTJ's Avatar
I thought the 04 had the DRL? My 07 does. Its a simple relay.
Old Jan 31, 2008 | 08:21 AM
NoRawkus305's Avatar
You are in luck. Here is a DIY I kept for myself if I ever decide to do it. Good luck and enjoy.
DRL DIY
Old Jan 31, 2008 | 08:40 AM
alejo's Avatar
nope, 06 is the first year with it in the US.
Old Jan 31, 2008 | 08:51 AM
s2kobsession's Avatar
that link provided above is the one the rest of us canadian importers have used. It's a bit of a pain to find the parts though since it was written a few years ago.
the HAMSAR module was a PITA to find... but I got it finally from the carquest in brampton i think...
Old Feb 1, 2008 | 03:03 AM
01SSAP1's Avatar
Interesting
When my car was imported from the US i guess they took the lazy route.
I bought my car in Canada from the guy that imported it.
My low beams aka the HID Projecters are hooked up to run whenever the ignition is on.
I am guessing that is the easiest way to do it but I am sure running the low beams constantly all the time is going to cause them to burnout quicker and from what I understand HID Bulbs are not cheap.
If I get really adventurous sometime I may do the proper conversion to the High Beams with the module.
Old Feb 1, 2008 | 04:53 AM
S2KJOY's Avatar
Thnaks for the replies - food for thought
I have a question - is the above suggestion application to the 2004 model?
I'm still sure which way to go at this point or perhaps I should try to befriend a Crappy Tire person to pass the inspection without the DRL.
91crxSi
Sep 15, 2013 09:52 PM
Refresh
Jul 9, 2012 06:55 PM
omg_miiiike
Nov 1, 2010 02:32 PM
Spec_Ops2087
Mar 23, 2009 12:25 PM
PSmith67
Mar 25, 2007 03:32 PM
