Debadge Help.
Old Jun 16, 2008 | 11:51 PM
NerveAgent's Avatar
Thumbs up Debadge Help.
So i decided to take off the "S2000" emblems on the sides. The left side went smooth, but the right side is a different story. It still faintly says "s2000".. I've tried goo gone and clay bar. Its smooth to the touch but, you can feel a little bump over where it is so, im assuming it can be removed. If you close your eyes and run your finger down the side of it you can distinctly feel something. What should i try next? Should i seek professional help? Anyone in the SCV of SFV wanna take a look?! Any advice is greatly appreciated. Thanks.
BTW it looks like this
NerveAgent's Avatar
BTW about the pic.. SSS
iphone was the only camera available at the time when the picture was taken.
Old Jun 16, 2008 | 11:54 PM
Rxmfn7's Avatar
A bit of light polishing compound and a buffer. If you dont have a buffer you can do it by hand, just use a microfiber cloth with the polishing compound, and rub.. and rub... and rub. After you do that apply a nice coat of wax. That shit SUCKS to get off, I just did mine last weekend.
Old Jun 16, 2008 | 11:56 PM
NerveAgent's Avatar
Light polishing compound and a buffer..I've never and don't know how to use these.. Did you have the same problem as I? What kind of polish compound do you recommend?
Old Jun 17, 2008 | 12:03 AM
Rxmfn7's Avatar
For just cheap parts store compound that you can get anywhere, I like the turtle wax stuff:
If you dont have alot of experience with a buffer, better off to just stick with the microfiber towels and do it by hand. You can easily burn the paint with a high speed buffer if you arent careful. Just be sure its a microfiber towel so that you dont scratch the paint. If youre uncomfortable doing this yourself and know of any decent body shop, Im sure you could just swing by and if they are nice enough come buff that out for you in like 5 min.
Old Jun 17, 2008 | 12:09 AM
Rxmfn7's Avatar
Honestly even that polishing compound isnt really meant to be used with a high-speed buffer, its too coarse... but I had a nice microfiber buffing pad and have been detailing cars for years, and I knew what I could do with it. As I said above, stick with just using your hand and the cloth, it will come out eventually, but be prepared to be there for a while and have some sore fingers.
Old Jun 17, 2008 | 03:19 AM
Looter's Avatar
"WD-40"..................
Old Jun 17, 2008 | 05:05 AM
SDSILVERM3's Avatar
How about a heat gun to soften up the goo? Then perhaps a little alcohol.
Old Jun 17, 2008 | 05:33 AM
yusukeg's Avatar
When I took mine off I used a LOT of Goo Gone. I did soften up the glue from time to time with a heat gun like SDSILVERM3 said.
Old Jun 17, 2008 | 05:47 AM
NerveAgent's Avatar
I was thinking it probably it wasn't goo, because it wouldn't come off with the Goo Gone. I going to try to take it off later today. I'll post results.
