Debadge Help.
Old Jun 17, 2008 | 06:29 PM
  #21
Harpoon's Avatar
3M adhesive remover is what you want. You don't need to use heat or anything other than spray on the 3M and try to not let any of it get in your lungs.
I removed the badges from my car and the areas looked exactly like your picture.
3M can be a pain to find, but it is the only thing that seems to work for these situations.
Old Jun 17, 2008 | 07:23 PM
  #22
NerveAgent's Avatar
Originally Posted by RTZX9R,Jun 17 2008, 06:24 PM
I have a white S2k and went to the red H badges on the front and rear in December. When I removed the front, there was some blue staining under the badge, reminents of (junk BTW) turtle wax ice wax. IT would not come off with as much as carb cleaner, and I had to let the strong Florida sun bleach it out for about 5 months - to which it is now gone.
Sorry for no help - but you are not alone...
Hmm.. i've used that it might be..
I tried rubbing and polishing compounds.. I don't know if im doing it right but its still there.. How much of the polish am i suppose to use on the buffer and for how long?? I tried it for about 5-10 seconds at a time and its still there.. Tried it for about 5 min.
Old Jun 17, 2008 | 07:27 PM
  #23
NerveAgent's Avatar
Hmm.. i'll go out and buy some. In what way did you apply it?
Old Jun 17, 2008 | 07:47 PM
  #24
Harpoon's Avatar
Spray a bunch on with a towel under the area to prevent the runoff, wait 30 seconds and just rub it off with your finger or a microfibre towel. The 3M will chemically react with the adhesive and make it rubber-like. You might have to spray a bit more on the area as you work it.
Old Jun 17, 2008 | 07:49 PM
  #25
03supers2k's Avatar
WD40 FTW I couldnt get of the dumb windshield tape used wd and it came off so easy i felt like an idiot
Old Jun 17, 2008 | 08:51 PM
  #26
NerveAgent's Avatar
Holy smokes that is EXPENSIVE http://www.thenerds.net/3M.3M_6040_Citrus_...u=6040%5E~%5E3M
imma try to find somewhere cheaper local.
Old Jun 17, 2008 | 09:06 PM
  #27
Harpoon's Avatar
Holy smokes you're more high maintenance than my goomah:
http://www.amazon.com/24-Adhesive-Remover-...13765390&sr=8-1
Old Jun 17, 2008 | 10:46 PM
  #28
K7S2KGSXR750's Avatar
When i took the "H" off, i just used meguires Scratch X to get rid of the excess adhesive
Old Jun 18, 2008 | 05:44 AM
  #29
NerveAgent's Avatar
thanks i'm going try to pick it up at an osh or home depot. Ill post results later.
Old Jun 18, 2008 | 09:51 AM
  #30
TubeDriver's Avatar
Wax as-u-dry will remove that stuff.
So will WD-40.
lopez14
Feb 27, 2012 04:55 AM
tommygun124
Mar 20, 2009 05:06 PM
UsmcSway
Dec 9, 2008 07:49 AM
IXLR82
Apr 17, 2007 04:09 PM
MaxGeek
May 30, 2004 08:42 PM
