defroster switch question
Old Feb 13, 2005 | 06:23 PM
brerspidur's Avatar
Default defroster switch question
does anyone here have the rear defroster switch that goes opposite of the cruise switch? if so, does it click in like the cruise does? im wondering because i just got that switch to wire up some foglights, but it doesnt click. if you push it in, it just springs all the way back out when you let go of it, no clicking. but with the cruise switch you push it in, it clicks and only comes out a little, then you push it in again, it clicks again and comes all the way out.i havent had a chance to install it yet, but im wondering if maybe the switch is bad before i take the time to hook it up.
Old Feb 13, 2005 | 06:37 PM
Beardie's Avatar
IIRC the defroster springs the whole way back out because it's on a timer. ie: it will switch off automatically after a period of time, so the switch has to be in the off position ready to go again.
Old Feb 13, 2005 | 06:40 PM
brerspidur's Avatar
thanks, makes sense, now i guess i will have to find some way to make it stay in since im using it as a toggle switch. i wish they would have told me that when i asked if i would be able to wire it as a toggle switch.
Old Feb 13, 2005 | 06:41 PM
Beardie's Avatar
Where did you get it from?
Old Feb 13, 2005 | 06:46 PM
Convict's Avatar
ahh good to know. While reading the post I remembered I had switched it on a couple days ago and didn't turn it off and was just htinking to myself I need to turn it off.
Old Feb 13, 2005 | 07:32 PM
brerspidur's Avatar
hardtopguy
Old Feb 16, 2005 | 02:06 PM
fmah's Avatar
Here's how you do it:
Gut the defroster switch. It's just a custom switch with parts that slide and make electrical contact. You can figure out how to disassemble it in a few minutes.
Use a dremel and clean up the parts that will interfere with the new switch that you will glue inside.
Get a DPST push on/push off switch from RadioShack or partsexpress.com. Wire it up and glue it inside the defroster switch body. The wiring is simple if you can already figure out how to hookup the defroster. Buy a new socket/plug set from RadioShack so that you can mount your switch easily. Use a heat gun to desolder the wires if necessary.
To get the insert out of the dash, drill a hole in it, put in a screw and yank on the screw with a vise-grip, using the screw as a handle.
Pop in the new switch after connecting up your socket/plug.
Old Feb 16, 2005 | 02:32 PM
Beardie's Avatar
Want me to price up a fog light switch from a stealer in the UK?
Old Feb 16, 2005 | 06:32 PM
brerspidur's Avatar
thanks for the help, i just finished wiring up the switch. i was actually able to get the "clicky" part out of the cruise switch and dremel a copy of it, added a spring and a correctly formed staple, and i got the click function working. as far as teh switch part, i basically did what you told me, i gutted another switch and put it in my new defroster/fog switch, and it works like a charm.
flyerr
Feb 2, 2015 08:05 AM
kostas_p89
Αγοραπωλησίες
Dec 5, 2014 04:15 AM
berlina2ks2k
Dec 16, 2013 09:12 AM
bubsie007
Nov 11, 2013 05:33 AM
bubsie007
Nov 10, 2013 04:32 AM
