DiGrappa X-Brace Installed!
Old May 6, 2003 | 05:55 PM
Stratocaster's Avatar
[QUOTE]Originally posted by ralper
[B]I'm pretty much sold.
Old May 6, 2003 | 05:58 PM
ralper's Avatar
Originally posted by Stratocaster
The install in easy. Remove 4 stock bolts, hold brace in location, screw in 4 new bolts. That is about it. I can do it in 10 minutes by my self. Including Jacking, and unjacking.
10 minutes by yourself means about 2 1/2 hours with my kids helping. Excellent. A great project for us.
Let me know when it's available
Old May 6, 2003 | 06:04 PM
[B]
Old May 6, 2003 | 06:17 PM
Kodokan_4's Avatar
Originally posted by rossmon1
it's been said in previous threads that the x brace really doesn't cause the motor or chassis to do anything dangerous in a crash. does anyone remember that?
I believe that was only someone's opinion, that the x-brace would break away (if it is the aluminum type), when the engine was pushed back. I, however totally disagree with that.
The only OEM piece blocking the engine from going under the car in a severe frontal impact, is the engine mount stiffener, which is a thin-walled tube construction. The engine mount stiffener is meant to collapse.
I believe that any additional structure added to this area will reduce the car's crash effectiveness, especially the addition of a huge, heavy piece of solid aluminum, which is designed for strength, not for breaking away.
-Pete
Old May 6, 2003 | 07:00 PM
wickerbill's Avatar
Look at how much of the engine is above the brace. Not much. The engine doesn't go straight down in the event of a collision. It's go back and down at an angle. I don't believe the angle is so severe that the brace would be a problem. Now, if you were putting a brace towards the back of the engine it may be a problem, but your pictures illustrate how much of the engine is above the brace and it's not enough to worry me at all.
Also, look at the huge crush zone at the front of this car. There's a good 2-1/2 to 3 feet of car before you even get to the engine. It would take a tremendous impact to even crush the car back to the engine and one even more ridiculous to then move the engine any significant amount.
Old May 6, 2003 | 07:29 PM
Kodokan_4's Avatar
[QUOTE]Originally posted by wickerbill
[B]Look at how much of the engine is above the brace.
Old May 7, 2003 | 05:35 AM
wickerbill's Avatar
I can't imagine that the engine mounts or whatever is used can translate that ridiculous amount of energy from a collision that wants to push the engine back and make it go straight down. It doesn't make sense at all. Even if the engine is already up against the firewall, that doesn't mean it can't hit the firewall as it's going down. The aim of the engine going down is to keep it from intruding on the passengers in the cabin. It doesn't need to go down that much to accomplish that.
Old May 7, 2003 | 01:07 PM
rossmon1's Avatar
AS far as the install. Unless tooling changes have been made, it is a very very tight fit and you need alot of patience to get all the bolts threaded w/o any crossthreading. definitely a job best done w/o the kids arround. This has been mentioned by many digrappa owners in the past besides me.
Old May 7, 2003 | 01:29 PM
This issue has been addressed by the new design, fittment should be much easier. Rick just posted a thread on the release of this new design. https://www.s2ki.com/forums/showthread.php?...threadid=121514
Old May 7, 2003 | 01:53 PM
Kodokan_4's Avatar
I had the same problem the first time I tried to install it. I believe I cross-threaded one of the holes, but I was still able to torque down the bolts.
This time I was very careful, and threaded all of the bolts in together, just a little at a time. No problems.
I'm glad this issue has been addressed.
The first time, it scared the crap out of me!
-Pete
