Dissembling the tail light
Old May 29, 2006 | 01:48 PM
iamhomin's Avatar
Default Dissembling the tail light
Is it possible to pull the outer glass from the tail light to pull out the lenses? My friend has the "chromed" lens from a 03' and would like to swap it with his 01' S2K, if it's even possible.
Any help? TIA.
Old May 29, 2006 | 08:16 PM
Avionics86's Avatar
Post
Yes it is possible to remove the clear plastic outer cover. Just follow the diffuser instructions from Ricks. It's harder to do, just be carefull pulling it apart because it will break, I know. Good luck
Old May 30, 2006 | 07:11 AM
WhiteS2k's Avatar
If your friend has the whole '03 tail light units, then why not just swap the units? Much easier than disassembling the tail lights and swapping the lenses.
On the other hand, if your friend only has the lenses with the rings from the '03, then you have already answered your own question "is it possible" because someone must have disassembled the '03 tail lights to remove the lenses.
Old May 30, 2006 | 11:36 AM
iamhomin's Avatar
^Actually the 03' lenses were taken out from a broken taillight. I guess dissembling the taillight isn't an easy DYI job.
Old May 30, 2006 | 12:23 PM
StockSH's Avatar
well.. I think it's very very hard to take it out.. without melting the glue.
They are glued and clipped in.. ( I tried! with my broken taillight for fun..)
Old May 30, 2006 | 05:57 PM
iamhomin's Avatar
I see. Thanks for the input!
badboy00z
Jun 30, 2009 01:18 PM
s2kmousee
NYC Metro Stock Exchange
Jan 27, 2009 02:11 PM
Keith
Oct 17, 2008 07:30 PM
falcone
Jul 21, 2006 07:00 AM
tongman
Sep 29, 2005 03:34 PM
