does 04+ hardtop fit a 00?
Old May 27, 2005 | 12:15 PM
superslows2k's Avatar
Default does 04+ hardtop fit a 00?
i got a 04 hardtop with the hardware which looks the same and mounts the same.
but my top wont align up to lock all 4 positions
i can either get the 2 fronts on or the 2 rears on. or i can get the 3 latches on but the driver side front windshield so that creats a big gap in the front
anyone know if its different? or do i just need to adjust something to make it fit
thanks
Old May 27, 2005 | 12:24 PM
NNY S2k's Avatar
As per the hard top manual: Fasten front latches 1st, then the rears. Works great for me ( once tried to tightened the rears 1st & didn't got a good fit). If this dosn't work for you you may need a slight adjustment somewhere. Oh, 1 top is for all. Good luck!
Old May 30, 2005 | 10:32 AM
michael ferguson's Avatar
Should fit straight on, if its a very small gap at the front i think there are small nuts on the clasps to loosen/ tighten the clasps to reduce squeaking, hopefully you could adjust the clasp to get a tighter fit.
Jake89
Oct 18, 2016 09:18 AM
mega_stream
May 12, 2009 03:36 AM
KevinBond
Sep 10, 2008 05:54 PM
YeLLoWs2knVA
Nov 1, 2004 08:44 PM
