Does anyone else have this problem?
Old Nov 6, 2009 | 08:30 AM
Sgt. Pepper's Avatar
Default Does anyone else have this problem?
When driving on the freeway I experience vibration of the car past the 75mph threshold. So much so that it's not just annoying but actually impedes my vision of far off objects. I have the car completely stock except for 1 inch lowered on tien springs and the soft top still on.
Any ideas?
Old Nov 6, 2009 | 08:34 AM
Y2KS2K34's Avatar
have your wheels and tires balanced... alot of high speed vibrations can come from that
Old Nov 6, 2009 | 08:35 AM
dammitjim's Avatar
Most likely
- Wheel balance
- Tire pressure
- Wheel lug torque (Your wheel is about to fall off or was mounted by an impact wielding gorilla)
- Need to swap CV cups or install driveshaft spacers
- Incorrect spring/suspension install including incorrectly torqued bolts
- Bad tire(s)
- Warped rotors
- Wheel bearing
- Control arm bushings
- Tie rods
- Ball joints
- Driveshaft or halfshafts screwed up or out of balance
- Diff problem
- Trans problem
- Alignment
- You're driving on the same crappy road all the time
- The car isn't vibrating, you are
Least likely
Old Nov 6, 2009 | 09:20 AM
berlinablackie's Avatar
I vote wheel balance!!!
Old Nov 6, 2009 | 09:31 AM
hondaphreak's Avatar
i vote the cars not vibrating you are!
Old Nov 6, 2009 | 10:22 PM
Suzukuh's Avatar
definitely look into wheel balancing. I just had my tires replaced and I had the worst vibration around certain speeds. Enough to shake the hell outta me the wheel and everything in the car it was crap.
Old Nov 8, 2009 | 06:10 AM
hyoseke's Avatar
Old Nov 9, 2009 | 12:05 PM
-jacob-'s Avatar
hahahahaha,
Old Nov 9, 2009 | 06:29 PM
Y2KS2K34's Avatar
wow... looks like theres a winner, dont balance the wheels... balance yourself!
Old Nov 9, 2009 | 06:30 PM
Y2KS2K34's Avatar
