Does anyone else have this problem?
Old Nov 10, 2009 | 01:57 AM
kaissi's Avatar
1 - Wheel balance
2 - CV Joints....common problem in S2K.. if it's on WOT then it's most likely CV Joints.
Old Nov 10, 2009 | 03:10 PM
rxtech06's Avatar
you need diff spacers to fix that problem.
evasive has them for sale.
t1-r half shaft spacers. should fix the problem.
Old Nov 12, 2009 | 10:12 AM
Reckon's Avatar
I have the same issue. I'm taking it by Honda tomorrow morning to check it out. Service guys said it sounded like wheel balance from what I described (which reaffirmed my suspicions). Might or might not get charged for the balance, depending on if they see it as part of my warranty, since I only got the car 3 weeks ago.
Old Nov 12, 2009 | 02:05 PM
ShiftGearAP1's Avatar
Rebalance wheels. It takes 10 min or less a wheel. If the problem exists, there is most likely an alignment problem. (check out your rear toe)
Old Nov 13, 2009 | 11:44 AM
Reckon's Avatar
Honda just told me that 3 of my wheels were out of balance. Not majorly, but enough that it would be causing the vibration issue at 75mph. I would definitely try that first and see if it cures the issue. I plan on testing it to see if its fixed in a little while when I can go get the car.
Good luck!
Old Nov 13, 2009 | 02:01 PM
starchland's Avatar
probably your half shafts vibrating. does it always do it? speed related? rpm related? what about coasting in neutral? how long have you had the vibration? how long have you been lowered? rule out a big black vibrator being under the seat ok.
RUNVTEC
Jun 13, 2013 11:03 PM
Fujin
18
Dec 4, 2011 01:06 PM
chino101
Aug 18, 2011 08:14 AM
JDMQuip
San Diego S2000 Owners
24
Jan 27, 2010 02:50 AM
WindchaserS2K
Aug 14, 2006 09:39 PM
