Does the S2000 need premium gas?
Old Oct 9, 2002 | 09:00 AM
DWynne's Avatar
Default Does the S2000 need premium gas?
Premium gas? Regular? Mid-grade?
Just wondering. I always assumed the S2000 took premium (based on the HP per liter) but did not notice anything about it in the literature.
My BMW daily driver and the 'vette both take the expensive stuff and I was thinking if I could VTEC on regular that would be a big plus
Thanks,
Dennis
Old Oct 9, 2002 | 09:01 AM
SkLz325's Avatar
yes the s2000 requires premium gas. i always fill up with 93 octane. i think honda recommends 91 octane or better.
Old Oct 9, 2002 | 09:31 AM
wickerbill's Avatar
Look on the inside of your fuel filler door and you'll see that it takes Premium. With a high compression engine like this, make sure you use it to help prevent any detonation problems.
Old Oct 9, 2002 | 10:46 AM
21wS2K's Avatar
91.5 or higher is what is required.
I always use Sunoco Ultra 94
Old Oct 9, 2002 | 10:55 AM
DWynne's Avatar
[QUOTE]Originally posted by wickerbill
[B]Look on the inside of your fuel filler door and you'll see that it takes Premium.
Old Oct 9, 2002 | 11:02 AM
ntphan's Avatar
You should put the recommended octane. High compression engines require higher octane. High octane gasoline is more stable at high pressure so that it would not spontaneously ignite from the heat created by the compression of the gas/air mixture; you don't want this to happen for best performance.
Old Oct 9, 2002 | 11:05 AM
DarioManfretti's Avatar
Originally posted by DWynne
When I look on the inside of MY filler doors it DOES say premium - but I don't have an S2000 (yet)
Thanks for the replies,
Dennis
I was hoping you weren't an owner (I saw you are an enthusiast, but some enthusiasts are also owners). I was ready to tell you to read your manual for the type of fuel. I always use Sunoco Ultra 94 as well.
Old Oct 9, 2002 | 11:15 AM
PokS2k's Avatar
Use premium. If you accidently put in lower octane the car will be ok, but you shouldn't make it a habit.
Old Oct 9, 2002 | 01:48 PM
Pixsurguy's Avatar
I've read (can't recall where) that it will run OK on mid-level gas, but will not make as much power. The engine computer will compensate for the lower octane. It is NOT a recommended practice.
Old Oct 9, 2002 | 01:54 PM
Kekoa's Avatar
Damn, where do guys get 91+ Octane gas?? I usually fill up at a Mobil or Chevron that carries 91 as its highest octane. Are you guys buying gas from race shops???
