Don't top off your gas tank - extreme example
Old Apr 30, 2003 | 12:35 PM
jelliotlevy's Avatar
Default Don't top off your gas tank - extreme example
Being an extrmely anal sort, I like to keep good records of gasoline mileage. So, when the automatic filler shut off engaged at 6.125 gallons, I figured: "What harm in putting in an additional .075 gallons to bring it up to 6.2 even?" After all, that is only 9.6 additional ounces of gasoline. Big mistake. Most of that 9.6 ounces ended up all over the left rear quarter panel, making one very gross mess. Ladies and gentlemen this is a most unusual automobile with a most unusual gas filler neck. I have learned my lesson - profit from my mistake.
Old Apr 30, 2003 | 12:41 PM
rworne's Avatar
Unusual it is. You can usually see down it a few inches to see the level of the fuel. I usually top it off once after the pump clicks off, never more than that. The fuel usually is an inch or two below the constricted opening the nozzle fits in.
I am also anal regarding keeping records of gas milage. I usually fill it up once a week, and every time it gets fuel at about 200 miles. I have an Excel spreadsheet going showing the car's progress.
Old Apr 30, 2003 | 01:16 PM
Jason B's Avatar
Yes, I've noticed this! Once it stops... learn that it's bascially FULL to the rim.
Old Apr 30, 2003 | 01:20 PM
Pakisho's Avatar
DAYUM!!! 200 miles per tank? You must, like, Vtec or something.
Old Apr 30, 2003 | 01:45 PM
V8NV-mys2k's Avatar
I too found this out the hard way. I too average about 200 miles per fill up, around 3-4 bars left.
Steve
Old Apr 30, 2003 | 01:51 PM
Pakisho's Avatar
Ahhhhh.
See, I fill up after its ALL gone.
I get about 270-280 per tank.
But Im also Anti-Vtec most of the time.
Old Apr 30, 2003 | 01:59 PM
DarioManfretti's Avatar
I'm able to put in almost two more gallons in my Explorer after the initial pump click off. However, I learned with my first fill-up that once the pump stops... that means no more.
Old Apr 30, 2003 | 02:04 PM
Ballistic's Avatar
yeah..can get 300/tank once in a while...thats mostly between my trips between VA and NJ -- need to keep it at 65 though...i guess air drag starts getting too much any higher than that.
Old Apr 30, 2003 | 02:08 PM
gomarlins3's Avatar
Wow, I'm getting over 500 miles per tank each week and it only takes about 9 gallons. Oh, wait, you mean the S2000, I thought you ment my Insight. Yeah, I fill up with about 3 bars left as well. I will start the pump again after it stops until it clicks off again, then that's it. I do this with all the vehicles.
Old Apr 30, 2003 | 03:18 PM
wanabe's Avatar
another one who keeps detailed records here...
and who has never gotten 200 miles out of a tank-
but i learned the topping off lesson my first fill.
i also have a "spill deflector" on the car (a rubber device that unrolls out of the gas fill area and keeps any overflow off of the car).
