Door inserts?
Old Sep 30, 2008 | 07:48 AM
common reactor's Avatar
Default Door inserts?
I searched for this and nothing came up surprisingly. I'm just wondering if the door insert (meaning the part that is sometimes red on the black/red interior) can be replaced without actually replacing the entire inner door panel with the speaker wiring and everything. Would it just be simple screws or adhesive? I'm sure someone has done this before...
Old Sep 30, 2008 | 09:45 AM
Saki GT's Avatar
I'm pretty sure its just glued on. There's a guy in the Atlanta forums who does custom interiors and can probably explain in greater detail.
Old Sep 30, 2008 | 09:55 AM
Saki GT's Avatar
https://www.s2ki.com/forums/index.php?showuser=36703
http://www.jpmaccessories.com/
Old Sep 30, 2008 | 09:59 AM
Thanks...who installs them though?
Old Sep 30, 2008 | 10:03 AM
Vi37573r's Avatar
the door inserts are held on by a couple of screws. I replaced my black one with a red one. It's pretty easy to swap them out too.
Old Sep 30, 2008 | 10:05 AM
roflitzjinno's Avatar
im sure you can install these yourself, the ones from jpmacessories.
Old Sep 30, 2008 | 11:57 AM
Reds2kracer's Avatar
It's held on by screws but it depends if the seller took off the leather part instead of the whole thing, if the seller took apart the leather and plastic peice then it's just a matter of lining it up and re-glueing it. It's a PITA to take it apart cuz you'll have to pull until it all comes apart, easier said then done (the leather and plastic backing peice that is).
Old Sep 30, 2008 | 08:42 PM
If it's screws then I have no worries.
NS_S2K
May 17, 2011 11:09 AM
getmadboy
Mar 5, 2010 01:30 PM
nj2tn
Jun 6, 2006 04:19 PM
caneintn
Jul 22, 2005 09:54 AM
