Door won't lock
Old Oct 12, 2021 | 09:58 AM
Bay2k's Avatar
Default Door won't lock
Please help
​​​​​my driver side door will not lock/unlock with the fob or manually do it.
Here are the video of it of me doing it manuallyhttps://youtu.be/vEMZGRfdGdM
Old Oct 12, 2021 | 11:14 AM
Chuck S's Avatar
To lock the opened drivers door requires pulling either the inside or outside door latch and then pressing the lock to the locked position. Standard Honda practice to help prevent locking yourself out of the car. Same to unlock the door. This is mechanical, not electrical, so if you can't lock the door when it's closed the door doesn't think it's closed, there's something mechanical not being activated.
Each door has a lock tab next to the
inside door handle. When you push
in the lock tab on the driver’s door,
both doors lock. Pulling out the lock
tab on the driver’s door only unlocks
that door. The lock tab on the
passenger’s door only locks and
unlocks that door.
To lock the passenger’s door when
getting out of the vehicle, push the
lock tab in and close the door. To
lock the driver’s door, remove the
key from the ignition switch, pull out
handle and push the lock tab in, then
close the door.
-- Chuck
Old Oct 12, 2021 | 12:26 PM
Bay2k's Avatar
-- Chuck
Even when I close the door the lock will not lock or unlock with the fob. It will get stuck like how it is in the video
Old Oct 12, 2021 | 01:50 PM
Chuck S's Avatar
The door probably thinks it's open -- and is operating as if it is.
-- Chuck
Old Oct 15, 2021 | 08:40 AM
twohoos's Avatar
^Chuck is correct, your door "thinks" it's open.
Can't tell in the video if it actually was open, but the behavior you filmed is correct for an open driver's door: the handle must be pulled to manually lock or unlock it. As a result, the remote fob doesn't work on an open driver's door (since the fob can't physically pull the handle -- natch!).
Old Oct 18, 2021 | 05:20 AM
NH_s2k_Guy's Avatar
I just had to replace a door lock actuator in my wife's 2014 Pilot so could be that as well.
lunar_s2k
Sep 8, 2013 09:04 AM
NA1NSXR
Apr 8, 2011 07:25 AM
DDuds2k
Aug 15, 2007 01:46 PM
B.C.
Apr 15, 2005 04:15 AM
wing
Nov 27, 2003 05:17 PM
