downshifting?
Old Mar 25, 2004 | 06:21 PM
NFRs2000NYC's Avatar
I always do the neutral + brakes, unless I am doing spirited driving, then I downshift.
Remember, brakes cost less than anything else.
Old Mar 25, 2004 | 06:52 PM
RazorV3's Avatar
it surprises me how many people who drive cars with a stick(not only the s2000) don't know how to properly downshift. sure you don't need to rev match(since modern cars have syncrhos to match engine and tranny speeds), but if you don't, it will be very jerky and not smooth at all. what is happening here is that the engine has to play catchup and match the speed of the transmision. this is why the car feels like it jumps forward.
you need to revmatch(blip the throttle to match engine and tranny speed) before you let go of the clutch if you do it right, the downshift will be very smooth and not noticable at all. people will complement you and tell you how it feels like you're driving an automatic. also the bad thing about NOT revmatching is that if you suddenly just pop off the clutch wihtout blipping the throttle, the rear wheels can lock up or start spinning and will make you lose control(especially in a turn). you will also prevent extra wear and tear on the clutch disk and other drivetrain components. less stress and shock = longer lifetime of parts.
some people will think that downshifting to slow down is overkill but if done properly, there will be no noticable extra wear and tear on the clutch. also there is a safety aspect to this. if you just leave it in neutral while coasting to a stop and some fool decides to cut you off(and slamming on the breaks is a bad idea since someone is on your tail). by the time you think of the correct to gear to select and execute the shift, it will be too late. i personally will not put in neutral until the car is travelling <5mph.
Old Mar 25, 2004 | 08:14 PM
Hate Me's Avatar
I just do whatever comes naturally...when turning I always downshift. When I feel that I'll come to a complete stop I just shift into neutral (may even save me a bit of gas money )
Old Mar 25, 2004 | 08:29 PM
xviper's Avatar
Umm, nope! When you decelerate in gear, your injectors are not squirting fuel. When you use your brakes, gear box in neutral, engine idling, injectors are working to keep the idle.
This issue has been discussed ad nauseum, so I'm not going into it too much. Suffice it to say that I rev-match downshifted an old VW and in 10 years and 100,000 miles, I changed the clutch once and the brakes 3 times. If you don't know how to drive, it'll be the other way around.
Old Mar 26, 2004 | 05:58 AM
RazorV3's Avatar
[QUOTE]Originally posted by xviper
Old Mar 26, 2004 | 06:11 AM
Tedow's Avatar
[QUOTE]Originally posted by Destiny2002
For "normal" street driving, good fuel economy, and least wear on the expensive components, you want to do neither of your two options.
Old Mar 26, 2004 | 06:15 AM
natedoggs2k's Avatar
Originally posted by Tedow
This is the way to go. Shifting to neutral right when you start braking is not smart, since you are not taking advantage of engine braking and you're using more fuel to keep the engine idling. And as has already been mentioned, you have no acceleration available should you need it in an emergency. Downshifting will save your brakes even more, at the potential cost of more clutch wear. Just leave the car in gear until the revs get real low, then put it in neutral.
Old Mar 26, 2004 | 07:05 AM
sirrach's Avatar
I believe in the manual it suggests using the engine braking in most cases.
Old Mar 26, 2004 | 07:29 AM
wanabe's Avatar
because of my exhaust, i love to "blip" the throttle then rev match...
always downshift!
Old Mar 26, 2004 | 11:10 AM
Hate Me's Avatar
