Drilled and slotted rotors question????
Old Oct 21, 2003 | 07:55 AM
krazik's Avatar
Administrator
1) cadiminum(sp) plating should hold up ok. Don't expect 0 rust tho.
2) It shouldn't increase anything that is measureable. The holes and slots remove from the contact surface area of rotor, but not significantly so.
3) Slotted and drilled rotors will crack a lot sooner than non slotted or drilled ones. Do you go to the track and/or are you hard on your brakes? If not (most arent) they'll last for a while before cracking.
Old Oct 21, 2003 | 08:10 AM
docofmind's Avatar
[QUOTE]Originally posted by sehenkel
Old Oct 21, 2003 | 08:25 AM
seung's Avatar
brake performance WILL decrease.
it looks good tho.
Old Oct 21, 2003 | 09:13 AM
slalom44's Avatar
Top Answer: 1
If you're going to replace your brakes eventually, why not just paint your stock rotors for now? Just clean off the rust (wire brush, etc), and spray them with a hi-temp paint. Several owners have painted them silver, and they look pretty good. I painted mine black (to hide the rust), and they've held up really well. It's a lot cheaper than plating.
Old Oct 27, 2003 | 10:07 AM
crockey's Avatar
Did you buy the rotors on ebay, and if so, how do you like them? I am looking at the same ones, but I am concerned that they are so cheap
Old Oct 27, 2003 | 10:30 AM
ttb's Avatar
ttb
yea, stay away from the drilled rotors. i used to want them too until i found out they are prone to cracking.
Old Oct 27, 2003 | 10:49 AM
docofmind's Avatar
Only downside i see to these rotors are that they are zinc plated and not cad which can actually degrade the quality of the metal.
Also, from the look of the pic, the holes do not look chamfferred. That also increases the likelihood of stress risers.
jackblack
Mar 15, 2011 09:47 PM
moey1188
Apr 12, 2007 04:27 AM
kaansahbaz
Feb 12, 2007 09:37 PM
Ro_Ja Boy
Aug 3, 2004 04:20 PM
Sebring Silvur
Sep 17, 2002 05:52 PM
