? driveshaft, U-joint, or differential problems
Old Jul 5, 2001 | 01:37 PM
tram57's Avatar
Default ? driveshaft, U-joint, or differential problems
Wanted to post for feedback concerning a new problem. I welcome any comments. I have about 4200 miles on my '00 and over the last 300 or so miles I have noticed a low frequency rumbling vibration/resonance at 62-66 MPH which is felt as much as heard and which is evident under steady speed in 5th gear, or 6th gear (minimal throttle opening), and also while coasting though of a lesser amplitude than when in gear. Has been getting more noticable recently. Seems dependent on road speed. Sounds like a bad U-joint or something in the drive shaft or differential. Since it is independent of engine RPM, I feel I can't blame the clutch/pressure plate or input shaft of the tranny even though I haven't had the clutch disc TSB done. Anyone else? The car has been driven spiritedly; however, no drag racing, hole shots, and very infrequent V-tech in 1st gear.
Old Aug 4, 2002 | 08:17 AM
mdrx7's Avatar
I got the same problem. My guess is a U joint also which I am going to get it check this week.
Old Aug 4, 2002 | 01:20 PM
CoralDoc's Avatar
Wow, that was a long time for the first reply!
One problem with the U-joint hypothesis - there are none on our car . There are CV (constant velocity) joints on the half-shafts (Honda calls these "drive shafts"). There are no joints on the main drive shaft (Honda calls this a "propellor shaft") because the transmission and differential are fixed to the chassis so they do not move relative to each other.
Old Aug 4, 2002 | 03:42 PM
boiler's Avatar
Sounds like a typical CV joint problem. There have been numerous owners with CV joint problems. I don't know if you folks have had a chance to see the drivetrain setup on our cars or not, but it's pretty cool. The driveshaft looks different than anything I have ever seen before and it has no u-joints in it at all. It's solidly bolted to the transmission and the differential.
I also saw something that I didn't expect to see...a big rock rattling around in the frame of the charcoal canister. One less noise to worry about.
Old Aug 5, 2002 | 11:53 AM
j2k's Avatar
j2k
uh... the driveshaft (aka "propeller shaft") also has CV joints at each end.
-jason keeney
SARmedic
Apr 4, 2011 10:50 AM
Shovell242
Apr 23, 2007 03:34 PM
Friday03
Oct 6, 2003 06:30 PM
DWynne
Apr 19, 2003 07:58 PM
