DUMB QUESTION
Old Nov 12, 2005 | 05:57 AM
jdnissanz's Avatar
Default DUMB QUESTION
Anyway, I am installing a turbo next week, but mainly when I change wheels I ahve a jack set, but IDK where to jack teh car from the middle fron and rear if that makes sense...Meaning I don't want to do all four seperate corners at different times, rather two at a time (front then rear)...Where are the SAFE jack points for lifting the car from the middle pics would be the best
Old Nov 12, 2005 | 06:07 AM
ruexp67's Avatar
You are installing a turbo, but don't know how to jack up the car?
The rear jack point is the diff housing, the area around the drain plug.
The front point is on the crossmember, but you are not likely to get the jack under the front.
It's better to jack from the side points. You can lift the whole side at a time and can place your jack stands on that side, then go lift the other side the same way.
Old Nov 12, 2005 | 06:08 AM
Enthralled's Avatar
Depending on how low your car is i believe you need the little jack to get it up a little before you lift the front end with the big jack.won't fit otherwise.once you have the car up with the little jack you can see under the car and you will see where you need to jack it up from.It's under the engine area.same thing on other end
Peace
Old Nov 12, 2005 | 06:10 AM
jdnissanz's Avatar
I am not an idiot I know hot to jack my car, just that I could never fit a jack under through the middle so wondering what other ways to get to those jack points...
Old Nov 12, 2005 | 06:13 AM
Enthralled's Avatar
Like i said get the little jack, lift a little then put the big one in the middle
Old Nov 12, 2005 | 07:11 AM
xviper's Avatar
Or drive the front tires up onto some 2X8" boards to get the jack to the front center jacking point. The rear should be already accessible.
Old Nov 12, 2005 | 07:41 AM
darkfx's Avatar
to fit my jack under my S i just pick up the cart by the fender then have an assistant put the jack under the car
Old Nov 12, 2005 | 07:56 AM
xviper's Avatar
rpg51
Nov 17, 2016 02:41 PM
spartikus1975
Nov 29, 2009 07:29 PM
mah00si
Apr 24, 2008 09:06 AM
euan
Nov 27, 2003 04:14 AM
KaiWang
Oct 6, 2001 02:59 PM
