Dyno pulls in 5th? or 4th
Old Jun 5, 2007 | 07:21 PM
Borbor's Avatar
Default Dyno pulls in 5th? or 4th
Considering the 5th gear is 0.97 and 4th is 1.161, I'm guessing I should do my pulls in 5th gear?
Old Jun 5, 2007 | 07:41 PM
nicku's Avatar
4th...i did mine on the 4th
Old Jun 5, 2007 | 08:45 PM
Elistan's Avatar
I've always done mine in 3rd, to reduce the time that the engine is at 100% load and thereby reduce the amount of head produced. The S2000 transmission does not have any gear that's 1:1, so they're all pretty much equal when it comes to losses. On some transmissions that had a 1:1 ratio for one of the gears, it was simply a direct engagement of the shaft, no gears involved at all, which is why it showed less loss. Again, our transmissions don't work that way.
Old Jun 6, 2007 | 04:14 AM
S2KPUDDYDAD's Avatar
I have an AP1, pull in 4th with AP2 transmission. Not sure how close that is to 1 to 1
Old Jun 7, 2007 | 05:17 PM
minboost's Avatar
i've been told you should do pulls in whatever gears tops out closest to 100mph.
maybe that's the quick and dirty way to find the gear closest to 1:1??
Old Jun 7, 2007 | 05:53 PM
iam7head's Avatar
ap1
R:2.8
3.133
2.045
1.481
1.161
0.971
0.811
actually the fifth gear is closer to 1.00(-.029 vs 4th gear .0161), but most tuner never use a overdriven gear for dyno for some reason.
ap2
R 2.8
3.133
2.045
1.481
1.161
0.943
0.765
Old Jun 7, 2007 | 09:34 PM
Eluded's Avatar
try a 3rd vs 4th vs 5th and post the numbers....
Old Jun 7, 2007 | 09:40 PM
Enthralled's Avatar
I did mine one time in third and twice in fourth.
I got 290 something in third and 310 in fourth on a dynojet.
SLINKYDOG
Apr 24, 2010 02:46 PM
s2konroids
Jul 2, 2009 12:38 PM
pinoyk20
Mar 12, 2009 04:20 PM
djweaver
Feb 24, 2006 12:02 PM
BAD S2K
Mar 9, 2002 06:25 PM
