ECU 00-01 upgrade
Old Jun 4, 2009 | 03:45 PM
Rollinx25's Avatar
Thumbs up ECU 00-01 upgrade
What changes on the 03' ecu to make it better for the 00-01 s2k's?
Old Jun 4, 2009 | 04:51 PM
Suzuka_Joe's Avatar
you meant to say was
"what changes on the 02' ecu make it better than 00-01 s2k's?"
the change occured in the 2002 model year. i'm not sure what they are but the 02-03's make a little more power and have better fuel economy. this should probably be moved to the s2000 talk forum anyways
Old Jun 4, 2009 | 05:38 PM
ahrmike's Avatar
More power because they leaned out the fuel mixture. This also makes your car get better gas mileage.
Old Jun 4, 2009 | 06:05 PM
NDAZONE's Avatar
If the ECU update for 2002 made a noticeable power increase wouldn't Honda or some car magazine have mentioned this improvement? As far as I know the car was always quoted at 240 (237) hp. I'm not disputing, just questioning.
Old Jun 5, 2009 | 05:37 AM
vtec9's Avatar
F22C makes noticeably more power than the F20C but the rating didn't change either. 02-03 will make 5ish hp more thanks to a leaner mixture.
Old Jun 5, 2009 | 05:52 AM
kchandra's Avatar
Staying on point, what does conversion at a dealer entail as far as immboilizer goes...
I have an 03 ECU from a wrecker and the VIN confirming it was wrecked on the invoice.
Will any dealer swap it over -can I get it done online? Also, how much does this cost per dealer labor hours?
Thanks!
Old Jun 5, 2009 | 07:56 AM
Rollinx25's Avatar
You can swap it yourself and just have the dealership reprogram it for your key to work.
Old Jun 5, 2009 | 08:59 AM
EVAN&MONICA's Avatar
search??? sorry had to. Its been covered so many times...
02-03 got leaned out and has better tune at partial throttle
Whether it makes more power is negligible
It certainly should get slightly better mileage per gallon
Old Jun 5, 2009 | 10:57 AM
vader1's Avatar
I did the swap some time ago. I think its a combination of SLIGHTLY more agressive timng on the low end and maybe a little leaner I don't don't know for sure about that though. It has a little more pep and I liked the fact that I did it for about $100.
But with virtually the same driving style I am getting about a mile or two per gallon less over the last couple years after the switch. Who knows, that could be the fault of another gremlin.
Old Jun 6, 2009 | 07:48 AM
Artric's Avatar
Leaner is meaner!
