Engine blown
Old May 14, 2007 | 04:20 PM
  #101
RED MX5's Avatar
[QUOTE=GTI 20v,May 14 2007, 06:54 PM]I suck, yet you agree with me?
Old May 14, 2007 | 07:36 PM
  #102
jimbogxp's Avatar
Originally Posted by Blacknot,May 12 2007, 08:59 PM
I dont care how much you beat on your car. A stock S2000 should not throw a rod or blow up with 57k on it. Honda did not get thier reputation from cars like that. it's not like he said he has tranny problems or a blow diff. He threw a rod on a stock motor with 57k. That' BS!!!
I am not a car expert. Just logical.
I can see the strain on a rod being higher at 9,000 rpm than at 1,000 rpm. The piston has to accelerate much faster, so I would expect the force, to be higher, causing more stress and strain on the rod.
Also, not all 57k engines are equal. How many piston cycles does it take to go 57k in 2nd gear, vs. 6th gear. The more time you spend in 1st and 2nd gear, rather than 5th gear, the more wear and tear your engine is going to take becuase your pistons are going to have far more cycles on them. So a person who drives in 2nd and 3rd gear exclusively, keeping the engine above 7500 RPM all the time, is going to have FAR MORE wear on his 57k engine, than a person stays in 4th and 5th gear all the time.
Again, not an expert. Just pointing out that 57k is not too early to suffer catastrophic damage under the right circumstances of use or abuse, proper maintenance not-withstanding.
Old May 14, 2007 | 08:45 PM
  #103
RED MX5's Avatar
The thing is, the strain is not on the bearing, it's on the oil film between the bearing shells. As long as that film does it's job, the bearing won't turn, and the kind of treatment it would take to overwhelm that oil film would tear up other parts of the car first. What happens is that the high revs actually wear the oil out faster, but the bearings aren't really affected.
Most bearing wear actually takes place during a cold start before a good supply of oil ever reaches the main bearings. During that time the oil film is made up only of the oil that hasn't drained out of the bearings, so the chance of metal to metal contact (and the associated wear) goes up.
You will do FAR more harm to this car by taking many short trips than you will by driving it hard.
Old May 14, 2007 | 08:57 PM
  #104
CKit's Avatar
Is this thread still living on?
Old May 14, 2007 | 09:16 PM
  #105
RED MX5's Avatar
[QUOTE=jimbogxp,May 14 2007, 10:36 PM]Also, not all 57k engines are equal.
Old May 14, 2007 | 09:21 PM
  #106
RED MX5's Avatar
I'm considering turning it over to the Government's Search for Terrestrial Intelligence.
The thread blew past dumb on page one like it wasn't there, and has been picking up speed ever since.
If you break or wreck your car don't be a dumbass and share it with your friends here on S2kI. You can see what happens. Just let them make their own mistakes.
Old May 23, 2007 | 11:57 AM
  #107
SheDrivesIt's Avatar
Like a witch burnin.
Old May 23, 2007 | 04:08 PM
  #108
RED MX5's Avatar
Burnin' rubber is more fun.
I think this thread was better off dead.
Dasher
Aug 23, 2010 12:46 PM
golfnut311
Sep 11, 2005 04:40 PM
LITE BLUE
Nov 7, 2003 08:02 PM
Choo Choo
Feb 8, 2002 09:17 AM
RUGBY
May 22, 2001 05:07 AM
