Engine Bogging!!
Old Apr 11, 2003 | 06:50 AM
  #21
xviper's Avatar
Originally posted by GregC21
I was roughly revved to about 1500 to 2000 RPM's. I never usually have this problem. Most of the time I dont have to give it lots of gas. So your saying that I should rev to at least 2500?? I just dont want to put any excessive wear on the clutch!
From this description, I'd say that your driving habit in this scenario is one of low rpm, moderate clutch slippage starting from a standstill. On the most part, you can get away with this, however, when confronted with the type of circumstance of being in the intersection, turning and finding yourself having to move off quickly, you may have released your clutch just a bit more quickly than you normally would. This creates a situation of relatively high load, low rpm (thus low torque), too much throttle too late (too far into the clutch release). Even a Viper V-10 can be made to do this under similar conditions.
Next time, use a bit more throttle and a bit more clutch modulation when facing a similar scenario.
Old Apr 11, 2003 | 07:09 AM
  #22
reds2's Avatar
You can get the heat shield from nzaizar, he is in the thread. The JR filter is carried by Import Development (site sponsor) ~$60 plus shipping. You'll also need a cleaning kit for the filter.
Old Apr 11, 2003 | 07:27 AM
  #23
GregC21's Avatar
XVIPER, thanks for the helpful info! I guess I need to start revving it up alittle more than I have been. I was just babying it to much.
Greg
Old Apr 11, 2003 | 07:30 AM
  #24
RoBD305's Avatar
I agree with xviper. I had this same problem and went to the Honda Dealer to get it checked out. They had an S2000 specialist who was a former race-car driver test the car out and he was able to re-create the boggin at his will. He told me it was my way of driving and that the engine needs to be revved higher. Hope this helps.
Old Apr 11, 2003 | 07:31 AM
  #25
GregC21's Avatar
DJohnson, Hydraulics are used to make ones car jump up and down.
Old Apr 11, 2003 | 08:04 AM
  #26
s9000's Avatar
I think I have had the same problem a few times. I will be just putting in 1st gear at 2000rpms - around a parking lot for instance - going about 8 or 9mph when the car will just start to lurch violently back and forth (front to back) as if the engine is going OFF-ON-OFF-ON-OFF-ON. This will last for a few seconds and can be remedied by applying some throttle. It only happens when I am moving at a constant, low rpm in 1st - not when accelerating. This happens to me about once every 2 months.
Old Apr 11, 2003 | 08:10 AM
  #27
RazorV3's Avatar
[QUOTE]Originally posted by s9000
[B]I think I have had the same problem a few times.
Old Apr 11, 2003 | 08:21 AM
  #28
GregC21's Avatar
This is alittle off subject, but since we have all had this "bogging" problem happen at least once, What was everyones most embarressing moment with it? When it happened to me, There was a car full of women in the lane next to me, and of course I didnt give it enough gas, and jerk, jerk, jerk. Therefore, I looked in my rear view mirror and they were laughing at me. My face was probably as red as a tomato. So whats you guys' most embarressing moments?
Greg
Old Apr 11, 2003 | 11:41 AM
  #29
xviper's Avatar
The UK and Australian boys call it "bucking" and "kangarooing". There is an instant fix for this scenario. In time you will learn not to do it but you will also learn very quickly that you have tried to move the car off incorrectly and know that embarrassment is just a second or two away. When this begins, immediately push your clutch to the floor, blip the throttle and go again, but this time, the "right" way.
Old Apr 11, 2003 | 02:16 PM
  #30
Canucks2k's Avatar
Little 2 quick on the gear change from 1st to 2nd and GGGGRRRRRRRIIIIIIIINNNNNNNDDDDD REV REV REV
P
