Engine Cover Paint Cracking/Flaking/Peeling
Old Dec 6, 2014 | 06:30 PM
fernando.'s Avatar
Originally Posted by TougeHorseman
I wouldn't be concerned abiut peeling paint on the valve cover. What's more important is what is under the cover.
+juan
Old Dec 8, 2014 | 05:01 PM
slalom44's Avatar
Top Answer: 1
The valve cover is cast aluminum. The thermal expansion coefficient of aluminum is almost twice that of steel. In other words, every time you go from a cold to a hot engine, the valve cover gets bigger. The surface of the valve cover grows too - almost twice as much as a steel valve cover.
The paint's thermal expansion coefficient is much less. I don't know what it is, but it's likely less than steel. Therefore the more heat cycles the valve cover undergoes, the more prone it is to have the paint peel off. The greater the extremes in temperature the faster this happens as well.
There's nothing wrong with the cover. Most aluminum valve covers aren't even painted and they look pretty bad years later. Honda chose to make the S2000 look sharp with the hood up, and that's the price you pay.
Old Dec 8, 2014 | 07:04 PM
516S2K's Avatar
Good point
Old Dec 9, 2014 | 03:51 AM
redlineracing's Avatar
Never heard of this prob.My 03 with 100k looks great.Maybe someone repainted your cover with the wrong kind of paint.
\rlr
Carolina
Old Dec 10, 2014 | 02:59 AM
slalom44's Avatar
Top Answer: 1
Originally Posted by redlineracing
Never heard of this prob.My 03 with 100k looks great.Maybe someone repainted your cover with the wrong kind of paint. \rlr Carolina
My "03 cover looked great after 100k too. Still looked great after 200k. But around 250k flakes started to come off. At 330k it's lost a fair amount. Last winter's cold extremes in the Midwest didn't help.
Old Jul 20, 2020 | 09:37 PM
analogbubbles's Avatar
Yeah, this is my thinking also. I'd take a 80k car with a pristine valve cover over a 60k car with flaking paint; the 80k car has had fewer heat cycles and fewer cold starts, which is where most engine wear happens. Probably been stored in a climate controlled garage too. Valve cover condition can tell you more than the odometer
Old Jul 23, 2020 | 11:21 AM
Deckoz's Avatar
This is all a mute argument
The valve cover is painted. Any oil that has gotten on it will cause paint failure.
The only way you are getting a non flaking PAINTED valve cover is to use a catalyzed urethane as a top coat. So your regular off the shelf clear coats will fail too. You need a top coat that has chemical resistance.
No OEM valve cover coating will stand up to solvent/chemicals. So you options are catalyzed urethane (2k clear gloss/matte) or powder coating.
You can sneeze the wrong way and make an OEM cover flake.
Passing a car up because of a flaking valve cover. LOL as another poster said, it's what's inside that matters.
Old Jul 24, 2020 | 06:44 AM
donkeykong's Avatar
Originally Posted by Gotpepsi
I have seen many valve covers with peeling paint. Once I see that the valve cover is peeling I usually just stay away from that car;...
Please don't say stuff like this in the community, that's the equivalent of saying...rock chips on the front bumper, RUN!
Failing paint on a portion of the engine that you can't put your hand on after driving shouldn't be a surprise and DEFINITELY shouldn't steer somebody away from an otherwise fine car. It's paint, it can fail anywhere on the car, probably more so where it's cooking every time you start your vehicle.
Old Jul 24, 2020 | 06:47 AM
donkeykong's Avatar
Ohhhhhh...just noticed I wandered into and posted in a thread started 6 years ago
Old Jul 24, 2020 | 06:57 AM
donkeykong's Avatar
WHAT?!
Please explain this, nothing of which you just said made any type of sense. A valve cover with flaking paint tells you absolutely NOTHING about a cars engine health. How did you come to the conclusion that the car with more miles has been started and driven less frequently than the car with fewer miles?! How did you come to the conclusion that a car that has 80k miles on it...must have been stored in a climate controlled garage?!
