Engine power problems
Old Mar 12, 2003 | 01:17 PM
xviper's Avatar
[QUOTE]Originally posted by nastinupe1
[B]I didn't mean to sound "rude".
Old Mar 12, 2003 | 01:36 PM
steve c's Avatar
DarioManfretti, I hope you mean because of english not being his 1st language, and not because he's French...
Probably a combination of the two ....
Old Mar 12, 2003 | 07:30 PM
Barry in Wyoming's Avatar
Old Mar 12, 2003 | 08:36 PM
S2Kay's Avatar
Where is the map sensor located? please dont flame for cuz i don't know.
Old Mar 12, 2003 | 08:57 PM
xviper's Avatar
On top of and bit to the side of the throttle body.
Old Mar 13, 2003 | 06:04 AM
Jazz_Bass66's Avatar
[B]Dude... you are so vague.
Old Mar 13, 2003 | 06:17 AM
You know The S2000 have some problems !!
There one man died in japan due to a transmission problem.
Two S2000 broken in Belgium due to Spark plugs failure
One in Switterland !!
And in France, me at this time !!
And I'm looking for more under the Net !!
I like HONDA, I've got a NSX, a CRX VTEC F90, a S800, a Prelude VTEC, and a S2000 (broken). Unfortunatly, I can't drive at this time since sept 2001 and for a few month ...
But I think that it's not normal to ...
Old Mar 13, 2003 | 06:40 AM
Intrepid175's Avatar
Originally posted by Jazz_Bass66
Have you had any TSB's done : what does it mean "TBS"?
Do you know what TSB's are : no
JC
Hi JC,
TSB = Technical Service Bullitin.
It is a document that the manufacturer (in this case, Honda) sends to the dealer to help them diagnose or correct a problem. It can offer recommendations on how to make an adjustments or on what parts to replace. TSB's are ususally intended to be between the manufacturer and the dealer. The manufacturer doesn't go out of it's way to let the general public see them although the Internet has made it a lot easier for us to find out about them.
The S2000 has had a couple of TSB's issued. The dealer, in most cases, will only act on the TSB if you specifically complain about the related problem. They will not tell you that they applied a TSB to your car unless you specifically ask so you may not know.
Good luck with your problem,
Steve R.
PS: I don't think your English is that bad. It's certainly better than my French and better than some of us who don't have the excuse of English as a second language!
PSS: To those of us who are assuming that English is JC's second language, that may not be the case. Most Europeans I've met spoke at least three languages and some, many more than that!
Old Mar 13, 2003 | 09:42 AM
thanks for your answer.
Yes i've got a TBS that explain the failures and the modifications to apply.
It's call : "recalled campaing for S2000 _ oil pump and spark plugs". There's three pages about the symptoms and modifications and some schemas.
You're rigth, english is not my second language.
I' speak french, japanese, portuguese, spanish, deutch and a little bit english.
JC
Old Mar 13, 2003 | 02:22 PM
GeorgeP's Avatar
Jazz, It sounds a lot like what you are describing is the rev limiter that kicks in around 6000 RPM when the engine is cold. Were most of the power losses shortly after you started driving the car each time or was the car fully warmed up?
bsalgado
Sep 12, 2017 05:21 AM
durtbikedude365
Nov 12, 2010 08:56 PM
r0cket247
Oct 7, 2009 09:19 AM
MOLLYSLIP
Oct 28, 2002 01:15 PM
s2kpdx01
Aug 17, 2002 09:56 AM
