Engine revs higher when cold
Originally Posted by SgtB,Feb 7 2009, 12:04 PM
The Idle Air Control Valve is located on a small passage around the throttle plate. If you pop your intake off you'll see a couple holes in front of the throttle plate. One is the iacv port. When the ecu sees a cold temp it cycles the iacv open and closed very quickly to allow a metered amount of air in. This small amount of air is plenty enough to raise the idle under no load.
parisbishop
Mar 14, 2011 02:28 PM
GrandMasterKhan
Feb 10, 2011 12:41 PM
Carwyn
Jan 7, 2009 11:48 AM
