engine sound
Old Mar 13, 2004 | 06:38 PM
jwocky's Avatar
Default engine sound
I recently purchased a preowned s2000 (2000 w/ 28k miles) and I've got a question regarding engine noise. In any gear, when I rev the engine to about 3-4k and just let go of the accelerator, the engine makes a vibrating sound (with a little bit of metallic vibrating) until it drops to about 2000 rpms. It sounds like what a loose exhaust would sound like (altho the sound is coming from the engine). However, at higher RPM's, when I stop depressing the accelerator, the engine doesn't make this sound and sounds smooth while the rpm's drop; that is, until it reaches about 3-4k's and starts making the sound again.
I know this is a real general description and it's hard to really diagnose things like this through mere descriptive words, but does anyone have any clue what this sound is, if it's common on s2k's, and how to fix it? The car is under warranty so I will bring it in for diagnosis, but I'd like the expertise of the users on this forum as well.
Thanks in advance.
Old Mar 13, 2004 | 06:45 PM
amongmany's Avatar
Sounds like the standard clutch buzz covered by TSB054 (if you're under warranty). It is in NO way detrimental to the vehicle; just noisy.
Old Mar 13, 2004 | 06:55 PM
RazorV3's Avatar
[QUOTE]Originally posted by munckee
Old Mar 13, 2004 | 08:03 PM
jwocky's Avatar
Yeah, that sounds right... it is a buzz/rattle type of sound. What a relief. Thanks for your replies. Any idea how long this TSB would take? I guess they have to open the whole transmission up to replace the clutch disk.
Old Mar 13, 2004 | 08:07 PM
RazorV3's Avatar
it takes as long as replacing a clutch obviously. by the time they get the car in the shop, it should only take 1-2 hours if the tech knows what he is doing.
zeroptzero
May 3, 2010 01:38 PM
Globetro
Nov 18, 2005 07:50 PM
schwett
Feb 21, 2003 04:28 PM
