Exhaust Change Woes - Any suggestions
In the process of changing out the stock exhaust on KAMcDonald's S2 yesterday evening we ran into a problem with the studs on the cat. It seems the nuts "bonded" for lack of a better word to the studs. One of the studs snapped off and one of them was pretty much stripped of the threads by the time we got the nut off. It seems as if those studs are actually a part of the cat. Has anyone else had a similar problem? If so what have you done to correct it? My thinking is to try and drill it out and through bolt it. Any / all suggestions would be greatly appreciated. Thanks a lot.
-BS2KT
-BS2KT
Yup...same thing happened to me on the bottom most bolt. I just used a rubber hammer and it came right out then replaced it with a bolt I had (I still need to go to honda to get the right one...), but it was really easy I didn't even take the cat off.
InVTEC
Jan 8, 2013 07:44 PM
JspecVtec
Nov 5, 2008 06:50 PM
